Yes, both videos were taken while sitting still. It does it sitting still, and while driving. It also does it with or without the clutch pressed.Does it do this when you're sitting still
Well it's going to get worse typically and present itself... That's just kind of a general statement.Yes, both videos were taken while sitting still. It does it sitting still, and while driving. It also does it with or without the clutch pressed.
Vibration noises has been my thought recently. The motor and tranny mounts look to be in good shape. It’s interesting that the grand Cherokee had stiffening braces between the engine and transmission. They show on the service manual for 05 wrangler, but I don’t see them on the parts list. Makes me wonder if it being a more luxury car needed to be quieter so they reduced vibes by adding those braces.How are the engine mounts? Could something be lightly contacting the engine as the motor vibrates side to side?
With the oil pan off try and rotate the crank and see if anything comes to light as it spins. A small piece off the OPDA as it turns might cause the tic as it spins in and out of contact. There could be a cracked piston skirt that flexes under load. While the pan is off check all the crank and rod torques. A loose cap might flex and tap as it rotates. These are all unlikely events, but it seems all the common issues have been checked.
Funny you say that, I saw your post earlier and was going to comment but I got busy. I'll tell you that I never did find a solution to it. I also know of a really nice low mile LJ that makes the same noise. Ironically they've all been 6 speeds. I'd like to see if any automatics have the issue or if the torque converter somehow mutes the noise. I think mine has it the worst out of any I've heard.I just bought at 2005 x with 38k miles on it, I've been looking for days and days and this is EXACTLY what I have the same exact noise and symptoms except mine is much more suttle. Its not very noticeable unless your in first or 2nd gear around 2k rpms then above that it gear and rpm it gets drowned out.
I sat in a 2004 automatic that was at a dealership and listened hard for the noise and didn't hear it, so I'm still not convinced it is how all 4.0's sound. Although it could be a 4.0 with 6 speed sound. I'm still curious what the root cause is.
Let me know what they say. I'd like to hear more opinions.Yeah I have no idea, I'm going to bring it to a mechanic near me soon and see if they have any ideas, my dad has been a car guy his whole life, rebuilding transmissions and drag racing and like he said its not exaust leak from what he can tell, he does say the muffler vibrates more than usual under load. We didn't really do that much research though.
Ya, but why does it only happen to manual transmissions when it clearly is an engine noise? My thought is the torque converter dampens engine harmonics. Maybe a heavier or fluid filled harmonic balancer would solve the problem.If you look around the interwebs you'll find this on all jeep forums and it seems like every mechanic says its normal and it seems to only happen with manual transmissions. I just went in 3 different jep forums everyone describing the same sound (like a deck of cards shuffling or a card in a bicycle wheel) and nobody has a solution.
Dealership said its totally normal with the 6 speed, its a resonance thing something about the torque converter. And because the previous owner but 31 inch tires on the car its more noticeable.Ya, but why does it only happen to manual transmissions when it clearly is an engine noise? My thought is the torque converter dampens engine harmonics. Maybe a heavier or fluid filled harmonic balancer would solve the problem.
31" tires doesn't have anything to do with it. I can replicate the noise while sitting parked. Also, my jeep came with 30" from the factory, so 1" isn't much of a difference.Dealership said its totally normal with the 6 speed, its a resonance thing something about the torque converter. And because the previous owner but 31 inch tires on the car its more noticeable.
Mine (and now mazepam) are 05-06 which don't use a distributor, but instead a cam position sensor. They are also known to cause noise from poor oiling. Mine has a brand new crown unit, which unfortunately did not solve my problem.I had a ticking noise and it sounded similar to yours. You could hear it inside & and outside the cab. I would start the engine and hear this tick, thought it was the fuel injectors. End result was while driving the distributor shaft wobbled so much the rotor struck the contacts in the rotor cap and broke apart (see attached).
