I'm planning to install tow bar mounting brackets to the front bumper of my 2004 LJ by removing the bumper pads and drilling into the round real bumper attached to the frame. This would make them mount higher than if mounted under the bumper like a PO had planned to do. There are now metal arms with one vertical hole welded to the frame that would be for a lighter weight A frame style bar. Simple and somewhat strong but I don't like the idea of how that might torque sideways if on an incline so I would rather go with a Curt two bolt horizontal bracket. Getting around to my question, is there any issue with drilling into the hollow round bar between the frame rails and using that for support? I would rather go directly off the frame but that might not be possible with a two bolt bracket.
Again, thoughts appreciated. Maybe someone has done this before. I plan to tow behind a motor home.
