I finally got mine installed and took pictures of the full install
First, you can pull back the rubber and get access to the connector. Take a picture of the color order just in case. Then use a shim of some form(I used an ice pick) to release the ends from the connector for easier running.
I then followed the wiring harness for the stock headlights and ran it through the grill. If I remember correctly the harness changes in the later years.
Then for getting it through the other side I found a ziptie super helpful. After I got it through I fangled it up over the light for a straighter run
Go back to your picture of the wire orders and reassemble
I then ran a ziptie through the back of both fuses and turned them on another ziptie.
Then just bundled/routed the wires. Within the next few weeks I will cut them down to shorter lengths to make it more manageable and clean up the passenger side of the bay
Disclaimer: I am not an electrician. I don't claim to be one. I don't even play one on TV.
