i got to thinking about the track bar and watched a few vids and read some articles. Not sure if its important if you change the OEM track bar when you put a 4" lift on or not.
Another question I have is Why would you get the entire OEM track bar when its not the track bar thats broken/ can you not replace the bushings inside the OEM track bar?? i guess you would have to have them pressed out and then then new pressed in?
I would like your opinions. and lets just say the old bushings are confirmed (bad). May be the boots are busted or .... but the track bar is not bent.
thanks.
thanks.
