Track bar tie rod end missing washers
EZ_Wrangler
Central Ohio
Long story short; Took the TJ to the shop for an alignment (I know, I know. I could do it myself. But I was in a crunch). ANYWAY, they said they couldn’t do it for 2 reasons.
1) “Track bar is loose” - their explanation was there was play in the tie rod end of the track bar (the driver side end).
Is this a standard tie rod end that I can replace? (Not sure if it is an aftermarket track bar or not).
2) “L/F arm is missing lock washers” - Tech showed me that there are washers on the outsides of the front control arms. Passenger side has them, driver side does not. So they said it was moving laterally too much to be aligned.
Do you know what size washers those are? Do I need those washers with adjustable control arms? (I have adjustables to put on, just never did).
Thanks in advance for reading and helping!
-EZ
707kevin
100% More Rubicon!
Oregon
Gonna need pictures of what they are describing.
There should be 0 lateral movement in the control arm mounting points. zero.
Tie Rod End.... or Track Bar?
Two separate items.
what one has play? The steering tie rod, or the suspension track bar?
Anyways. Photos Please.
EZ_Wrangler
EZ_Wrangler
Central Ohio
Two separate items.
I’m aware there should be zero play. I wasn’t asking how much play is allowed. I’m trying to to rectify the play.
And my track bar is adjustable on one end. The drivers side end (as mentioned above) it appears to be a “tie rod end “ type of part. Hence the question.
Pictures in next post.
EZ_Wrangler
EZ_Wrangler
Central Ohio
Passenger side front control arm (has washer between nut and bracket)
Drive side. No washer.
Track bar end
EZ_Wrangler
EZ_Wrangler
Central Ohio
LONGJP2
TJ Expert
Illinois
Are you wanting cam (adjustable) washers or just flat washers?
If it's torqued properly, it shouldn't move even with the small washer that's on there. It's not the washer that keeps it centered.
Or there's these.
