CMTJ TJ Enthusiast Joined Mar 31, 2017 Messages 248 Location Jacksonville, FL, United States May 22, 2017 #1 Where is everyone that needs one, getting their trans mount for the 42rle?? The one in the middle of the ginormous skid plate. The ones I have found look real cheesy.
Jerry Bransford Retired to more relaxed pastures... bye. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL May 22, 2017 #2 If they're rubber, that's what you want. Poly engine or transmission mounts will transmit additional vibration into the cab.
OP CMTJ TJ Enthusiast Joined Mar 31, 2017 Messages 248 Location Jacksonville, FL, United States May 22, 2017 #3 Yea I go with rubber but I guess the pics I see just make them look real bad. I will keep searching.
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 3,893 Location Brookings, Oregon May 22, 2017 #4 Try and get the Mopar replacement, the aftermarket so called rubber replacements tend to transmit a lot of vibrations.
Jerry Bransford Retired to more relaxed pastures... bye. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL May 22, 2017 #5 Mopar OE mount.... https://www.amazon.com/dp/B007PJFFCW/?tag=wranglerorg-20 Omix-Ada which gets good reviews... https://www.amazon.com/dp/B000FQ200M/?tag=wranglerorg-20
OP CMTJ TJ Enthusiast Joined Mar 31, 2017 Messages 248 Location Jacksonville, FL, United States May 22, 2017 #6 Thanks Jerry....dang that's pricey.
Jerry Bransford Retired to more relaxed pastures... bye. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL May 22, 2017 #7 CMTJ said: Thanks Jerry....dang that's pricey. Click to expand... I had just added a less costly Omix-Ada for you...
CodaMan California Escapee Supporting Member Joined Mar 9, 2017 Messages 4,635 Location Dover, Arkansas May 22, 2017 #8 The Omix-Ada one worked just fine for me ... no added vibrations.
