1. It's time to vote for the November 2017 "Ride of the Month"! Click here to vote. Voting will end on October 31st.
    Dismiss Notice
Trans shutter on start up
Discussion in 'TJ General Discussion' started by 05pf13, Oct 12, 2017.
  1. 05pf13
    05pf13 Member
    Thread Starter
    Jan 17, 2017
    83
    106
    Branford, CT, United States
    I have a 05 Sport with 6 speed trans. and no lift. I get a shuttering of trans and motor when letting clutch out slowly especially when backing up. Not sure if it has to do with trans or motor mounts or neither. I've got just over 100,000 on it. Has anyone else experienced this?
  2. derekmac
    derekmac TJ Addict
    Feb 10, 2016
    1,015
    939
    NS, Canada
    Maybe @Chris can move this to a better section of the forum where you'll have a better chance of getting an answer.
    To your question, it sounds like clutch chatter to me. Does your clutch slip at all when fully released (pedal all the way out)?
    Chris likes this.
  3. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    17,672
    8,721
    Salem, Oregon
    That sure sounds like failing transmission mounts to me, I think you hit the nail on the head.
  4. TJ4Jim
    TJ4Jim TJ Enthusiast
    Dec 9, 2015
    773
    481
    Brookings, Oregon
    Take a good look at your transmission mount, they tend to degrade over time and can cause a serious shudder. Get in there with something like a 2x4 and try prying the mount looking for any movement or separation.
  5. derekmac
    derekmac TJ Addict
    Feb 10, 2016
    1,015
    939
    NS, Canada
    When my transmount went, it didn't shudder, but it did clunk.
  6. TJ4Jim
    Dec 9, 2015
    773
    481
    Brookings, Oregon
    They will clunk with separation and shudder with degradation. (I like how that sounds)
    Chris likes this.
  7. 05pf13
    05pf13 Member
    Thread Starter
    Jan 17, 2017
    83
    106
    No slippage with clutch release, just shutters and sounds like its gonna fall out.
  8. ac_
    ac_ TJ Enthusiast
    Jun 15, 2017
    221
    188
    AZ, United States
    From the sounds of it, it sounds more like a warped flywheel. I bet this is more of a clutch issue. A shutter can be caused by either bad spring(s) in the clutch cover or a warped flywheel can do it too. In rare cases a hogged out pilot bushing can contribute too. In any case I would bet it is the clutch, and I would replace the pilot bearing, and have the flywheel machined true or replaced at the same time.
  9. TJ4Jim
    Dec 9, 2015
    773
    481
    Brookings, Oregon
    C
    Could be a clutch also, just so you are aware machining the flywheel is not recommended at the surface from the factory is slightly convex.
    jeepersoutpost and Chris like this.
  10. bobthetj03
    bobthetj03 TJ Addict
    Feb 3, 2017
    2,287
    2,106
    Lake County, California
    I vote clutch as well. Mine started chattering in reverse before the TO bearing finally puked. Replace the clutch, and get a new flywheel while you're in there.
  11. 05pf13
    05pf13 Member
    Thread Starter
    Jan 17, 2017
    83
    106
    So I crawl under to check trans mount and found all four bolts holding mount to trans were LOOSE! Two of them were about a half dozen or so turns loose. Went for ride and WAHLAH, no more shuttering. Have had Jeep for about five years and the noise had been there as long as I can remember. Never had any trans work done so no telling how long its been that way. Thanks everyone for all the tips.
    Kathy, Chris and derekmac like this.
  12. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    17,672
    8,721
    Salem, Oregon
    And so the saying goes... Keep it simple stupid!
    Usually the most difficult questions have the simplest answer. Ockham's Razor at it's finest.
    TJ4Jim likes this.
  13. ac_
    ac_ TJ Enthusiast
    Jun 15, 2017
    221
    188
    AZ, United States
    That is like finding a 100 dollar bill in your jacket on your way out to the movies.
    Congrats!!
    05pf13 likes this.
Share This Page
