Transfer case clunk
Jlasall1
Divide, CO
I've been looking through the forums for months and I've been unable to find someone who has the exact same issue as I have. The issue started initially when the vehicle was in 4-wheel drive and occurred much more with the wheels turning. However over time the clunk began as soon as the vehicle was put into four-wheel drive. I've attached a video, and I cannot tell if the issue is at the u-joint or the t case, obviously hoping that the former is the issue. Any input would be greatly appreciated!
Goatman
Upstate NY
Video wouldn't load, but I would replace the u-joints first. They could probably use a refresh anyway. If in doubt always do the cheap and easy first.
Jlasall1
Jlasall1
Divide, CO
I'll try re-uploading. I agree with that assessment, I'm just beyond poor right now and my Jeep is my only vehicle so I'm trying to figure how dire the situation is. What part of upstate are you from? I'm originally from NY and will likely be back there by Christmas (due to the previously mentioned poorness).
MaloStapalo
Release the Kraken
Веил, колорадо
Have you tried removing the front drive shaft and see if the noise is still there?
Jlasall1
Jlasall1
Divide, CO
I completely removed the front driveshaft and drove the vehicle. With four wheel drive engaged, the noise was gone. However if the transfer case isn't able to engage the front drive shaft and be put under load, how does this isolate the fault to the driveshaft? Also, I think I have a CV style driveshaft with an SYE eliminator, but can someone confirm?
Jlasall1
Jlasall1
Divide, CO
Outside Saratoga. Far enough away from Albany that I don't have to smell it.
Welcome to Albany, smell our burning trash. I grew up in Schoharie county. What is the trail situation in NY? I know there won't be any rock crawling like there is in Colorado, but I'm more into overlanding anyway. My research has shown that there isn't a whole lot, but I know there are a ton of dirt roads in the state.
Goatman
Upstate NY
That is a standard front shaft. They all came with the double Cardin on the transfer side. While it's out give it a good look at the ujoints. If in doubt they are easy and pretty cheap to do.
Reactions: Flivver250
Goatman
Upstate NY
I've only gotten back into the Jeep thang this Spring. Still going through or replacing everything first. Back in my CJ days there wasn't much for trails other than snowmobile trails around here. And the farmers dont like you driving in the hay fields in the Summer. We would always go to Vermont for fun. Cross the border and within 10 miles we could always find a trail to run and camp on. All the lawyers living in NY have sucked all the fun out of this POS state.
Jlasall1
Jlasall1
Divide, CO
Took me forever, but I got the CV rebuilt (I'm pretty sure this guy was the issue) and the two associated u-joints done. Has anyone ever seen a u-joint installed with the plastic retainer pins on the differential yoke end? Because that's what I have going on, so I get one last frustration before I finish up.
Flivver250
Dubai/Florida
A long time ago I used to have a Ben & Jerry's route all through that area. From Schenectady up to the Canadian border and over as far as Tupper Lake. Brutal winters in those parts. I grew up in Vermont.
Flivver250
Dubai/Florida
+1 on this. They are out, replace them and move on. If done right they should last a decade with normal use.
derekmac
NS, Canada
The factory u-joints had plastic injected retainers. They melt right out if you heat them with a torch.
Jlasall1
Jlasall1
Divide, CO
I got that far, but I'm at a loss as to how to get a new 1330 u-joint in there. The channels for the injection are far too deep to use clips, and there isn't anything on the inner lip to use in the inside clips.
Jlasall1
Jlasall1
Divide, CO
I have a 2006 LJ. I found this from 2015, and it says that the 2005 LJ in question uses the the 5-793x.
Front Driveshaft @ Pinion: 5-793x
Front Driveshaft @ CV: 5-1330x (edit: 5-790x is now obsolete)
Front Driveshaft @ T-Case: 5-1330x (edit: 5-790x is now obsolete)
CV Centering Yoke: 211996X
LJ Rubicon w/ Rear Driveshaft #585AA @ T-Case: 5-1330x
LJ Rubicon w/ Rear Driveshaft #585AA @ Pinion: 5-1330x
Jlasall1
Jlasall1
Divide, CO
Finally got around to reinstalling the driveshaft after running into every possible issue and delay. The new joints and the rebuilt CV did NOT solve the clunk when in 4WD. I took it out today after installing the driveshaft and a new transmission mount, and I am still getting excessive clunking when in 4WD. Running less than 5 mph on very level dirt, and it sounds like the transfer case is constantly slipping. Stuck my head out the window and I'm almost certain it's coming from the output end of the t case.
