Transmission Fluid Recommendation for 2002 Jeep Rubicon
joseph018
Minneapolis, MN, 55402, USA
Hey Jeep enthusiasts,
I recently became the proud owner of a 2002 Jeep Rubicon, and I'm seeking some advice regarding the appropriate transmission fluid to use. I want to make sure I'm using the right fluid to maintain the performance and longevity of my Jeep's transmission.
I've done some research, but I'm finding conflicting information about the recommended transmission fluid for my specific model year. Some sources suggest using ATF+4, while others mention other alternatives or even synthetic options. I'm a bit confused and would appreciate some guidance from those with experience.
If any of you have a 2002 Jeep Rubicon or are familiar with its transmission system, I would greatly appreciate your input. What transmission fluid have you been using, and have you noticed any improvements or encountered any issues with specific brands or types?
Your personal experiences and recommendations would be incredibly helpful in making an informed decision. I want to ensure I'm using a fluid that is compatible with my Jeep Rubicon's transmission system.
Thank you in advance for your assistance!
MichaelGH
Hemi ‘97
Lifetime Supporting Member
OHIIIIIIO
Jeep doesn't make a 2002 4 cylinder Rubicon. 🤫
I don’t care what sticker someone bought and put on the hood. I am only referring to him stating he has a 2002 automatic transmission. Of which the ATF+4 will work…
Goodness I hope he even knows for sure that it’s actually an automatic transmission 😐
Reactions: TheBoogieman
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
First, there is no such thing as a 2002 Rubicon. If your TJ is a 2002 it's not a Rubicon, someone must have simply placed a Rubicon sticker on its hood as the Rubicon wasn't introduced until 2003.
And if it's an automatic, yes ATF+4 is the correct ATF to use. No other type of ATF is correct for any Jeep automatic transmission. And all brands of ATF+4 will be a full synthetic since the ATF+4 specification includes it being a synthetic.
And if your TJ is actually a 2002 and has the four-cylinder engine, it's the 2.5L engine. The 2.4L didn't come along until 2003. And no Wrangler TJ Rubicon ever came with anything but the six cylinder 4.0 engine.
