So long story not short because it's long and annoying, I got a transmission rebuild and new clutch on my ax5 trans at cottman transmission shop in raleigh north carolina. They got it all done at an extremely high $2200 dollars later, I went in to get the car and it wouldn't go into any gear, the system needed more bleeding, they flipped the slave and I left, came back because it was still not completely bleed and my 5th gear was messed up. They bleed the system some more and it was fixed. Then I went back back because my 5th gear was still messed up, they "adjusted" it and said it needed to be broken in and that with 31" tires and 4 cylinders, I shouldn't need my 5th gear anyway. I left, still wasn't working and came back a month or so later. They finally fixed the 5th gear, turns out the synchro was messed up from the box, I had known that but nope I wasn't allowed to be right, only when threatened small claims court for not fixing it. There were a few other small issues, trouble getting into reverse and second was hard to get into. The reverse issue that still exists today is sometimes when I go to put the car in reverse, it won't completely go, it'll get stuck at that halfway point and wont go in. I have to them release the clutch pedal and re-engage it and then it will go in. They still haven't fixed this issue but anyway. After they fixed the 5th gear synchro I felt some weird feeling, noises from the transmission. Also, my clutch pedal engages when the pedal is basically fully released, maybe a 1/2 an inch from fully released. It's even harder to put the car in 2nd gear sometimes when driving, there's sometimes a thudding rattle type of noise but not always and just the other day before I brought it back to the shop because of all the other issues as well as it now being able to go into gear without the clutch being pressed. I got a very sassy call back today saying they couldn't find anything wrong with it, they did everything I said I thought I noticed when things would happen like stopping on an uphill, 2nd gear grind only when it's cold, and other things like that. They didn't address the issue in their voicemail of it going into gear without needing the clutch so I'm going to have to see if it still does that. What I'm asking is what should I do about this shop, small claims court, ask for my money back, i've wasted god knows how much gas going back and forth there and having to give my friend gas money to drive me there so many times since it's 25 minutes away from where I live. I don't know what to do because I've brought it there so many times and every time I get it back, one thing is fixed and something else is f***ed up. I need suggestions and help!
