I recently purchased a 2004 Rubicon 5MT with 92,000 miles on it about a month ago and everything has been smooth sailing for the most part. The other day while driving home from an OHV park I had an intermittent CEL flash on the dash and then go away. When I got home I pulled a P0300 and P0306 from my OBD tool.
Additional Context
Additional Context
- For the most part the engine has been running smooth over the last month
- While the CEL was flashing I was cruising around 70 mph on the highway and felt no noticeable change in engine performance
- On two separate occasions over the last month the Jeep had a hard time cranking over which required me to crank it over again to get it started
- The Jeep on two other occasions ran really rough at startup and exhibited some ticking which went away once warmed up
- The previous owner mentioned replacing a Camshaft Sensor recently so I'm probably going to rule that out
