I installed a short piece of insulation around the 4.0L engine's #3 injection per a TSB (technical service bulletin) which is for 2000-2004 engines. It took about ten minutes from start to finish.
http://www.wjjeeps.com/tsb/tsb_wj_1803103.pdf
I had recently noticed a minor misfire after restarting the hot engine which had sat a short while causing heat soak. It felt like a single cylinder misfire and pretty sure this TSB will resolve it. The TSB describes a condition in which heat from the exhaust manifold (header) causes fuel to partially vaporize in the #3 fuel injector that can cause misfires after heat soak This is fixed by insulating the injector from the heat.
I used the specified Mopar shield ordered from https://www.amazon.com/gp/product/B007O3QHDK/?tag=wranglerorg-20
Several reported that not all types of insulation tried were successful with this TSB so I went with the Mopar insulation p/n specified in the TSB. There's nothing to the TSB other than cut the piece of insulation contained with that p/n in half and wrap one half around the bottom of the injector and the other half around the top of the injector, then secure it with a ziptie. The insulation was came pre-split so it just slides over the injector.
