Anyone get a crack like this on the tub above the body mounts? Is this something in serious need of repair and what are some methods you guys would use? I have very basic welding skills.
What do you mean by overhead?Looks like a stress corrosion crack, if you cant weld overhead, find someone who can help you.
that would probably require the body mount to be removed, cut away the side to see what damage is there, remove and treat as much corrosion as possible, and then make a 18ga patch with the correct bend radius to roll around the bottom, then weld it in. Prime then paint..That is very thin steel. I think you would need a pretty large repair panel to do anything useful and those aren't exactly easy to weld. I'd check to be sure your body lift is all good like @strumble8 suggested and forget about it. Frame is all that really matters to me. As long as I can't see pavement under my feet I wouldn't worry too much about it.
Do you think it’s worth getting it done or just leave it? My only worry would be that there’s corrosion inside and the crack gets worsethat would probably require the body mount to be removed, cut away the side to see what damage is there, remove and treat as much corrosion as possible, and then make a 18ga patch with the correct bend radius to roll around the bottom, then weld it in. Prime then paint..
Hey did you ever post pics on you working on your jeep in the other thread?If it was mine, I'd have a good welding shop look at it and repair it. A good shop will know just what to do. An ounce of prevention........
Awesome had no idea that existed but seems like a great last resort option. I think I’d like to try and patch it first but it is also like this on the passenger side of the car same mount as well...If it’s just the only mount, from all the fab shops I talked to, the tub isn’t unsafe, but it is going to get worse. If you’re going to have someone work on it, have them replace that area with something like the Safe-T-cap part instead of just patching it up and having to do it again correctly after.
