justa4x498
I would much rather work on my locker pumps under the hood then drop all the savvy armor to work on them. Once you install a TT you realize there's little to no room to work on things without dropping the skid. I like to make things more practical.
With a little trimming you can use the OE compressor mounting bracket to mount them to the driver's side fender well. Especially nice is you can retain the rubber isolators between the compressors and mounting bracket. That's where I mounted mine ten years ago and it's been a great location.
i might be posting in the wring way,im new few min.ago but like where you moved pumps.cool.i have a 98 tj eith dana 44,s and rubicon lockers front and rear.They ran the electric eires and rubber hoses for motors but i have no schematic,i saw where you said black to ground and red to switched power.so i have a red,pink and black on front locker.So where would pink go please? And the rear has same colors on one plug but also one that is re and green going to one of the pumps.Im aware that their are wires from factory that go to switches inside the diff.to show you are locked in on both diffs but the dreen and red on front pump seems to run into pump close to the little pump motor.when it comes on out to the original connector it is tan with stripe and black i think.any way can you tell me how to wire these motors please they are from 2004 rubicon he said.i just dont know about the pink wires and of coarse that green and red is weird compared to other motor wiring,Sincerely Justa4x408,or Robert.Im sorry if i posted wrong,i have looked for my name but no luck and see you are a ring leader,anyones help truely appreciated.With a little trimming you can use the OE compressor mounting bracket to mount them to the driver's side fender well. Especially nice is you can retain the rubber isolators between the compressors and mounting bracket. That's where I mounted mine ten years ago and it's been a great location.
