Hi Everyone,
The issue of the turn signals and hazards not working seems to be a thing on this forum. I'm having an issue with mine as well, and looking for some help. I bought my 06 TJ Anniversary Edition a few months ago. The previous owner had switched out the stock front fenders and installed LED headlights and marker lights. He left all the original turn signals and marker lights installed, just taped up in the wheel wells. A few weeks ago when I turned on my right blinker, both the right and left front blinkers flashed and the rear blinker worked as it should. The left blinker worked normally. I thought one of the incandescent that was taped up had burned out so I replaced them with new LED bulbs. I had the same problem, but now when I pressed the hazard button it buzzed and didn't flash. After messing around with the hazard button a little more, the hazards and turn signals all stopped working. I purchased the recommended flasher relay for the LEDs, and installed that but nothing changed. I checked and replaced the fuse behind the glove box for the multifunction switch and that didn't solve it. I purchased and installed a new multifunction switch and still nothing. The headlights, running lights, and brake lights all still work as they should.
Does any one have any idea what might be the issue and how I might go about solving it?
Thanks!
Thanks!
