Tweezer's 2004 LJ
tweezer
tweezer
Jeep Enthusiast
Ohio
Alas, no. Been really busy with work.
I get it. It's been a busy couple months on my end too. I am hoping to settle a bit and knock out some of my list to get ready for Summer. It's a big list. Ha! I need to figure out gears, lockers, and axles. I am going work with the local shops to see what they can get/install and just knock that out.
tweezer
tweezer
Jeep Enthusiast
Ohio
Ok, so long time, no update. Jeep work has been slow this winter. I was able to disassemble and diagnose the issue with the metal grinding noise at full weight after installing the exogate. The bracket that ties it into the roll bar was not as tight as expected. After tightening up the roll bar tie in (as well as re-tourqing the rest of the bolts) and mounting the 35" spare, the grinding sound was gone.
My battery has died and required charging a couple of times this winter. Is it normal for the battery to die after a couple of months of sitting? I think the first time maybe I didn't charge it long enough for long term, but last weekend I charged for 10 hours or so and I think that worked. I plan to drive it more that Spring has arrived, which hopefully will keep the battery charged up.
I have a long list of mods, so I reached out to my local 4WP. They previously installed my SSYE kit and Tom Woods rear drive shaft. Today, I signed off on 5.13 Revolution gears, chromoly Revolution axles front and rear, ARB lockers front and rear with the twin compressor and manifold, and Power Stop brakes front and rear. They're also going to install the Swayloc I bought last fall.
From there, I have a Savvy GTS to install and some rear frame cleanup. I am also going to install the Currie 1" BL, and a suspension cycling is in order. I bought a Bestop Safari top (as an option to the Bestop soft top I bought last year) and Bestop soft doors for the summer. I might also upgrade to Fox 2.0 reservoir shocks. I am stoked for the next couple of months. More to come.
Reactions: PNW_LJ and Rickyd
tweezer
tweezer
Jeep Enthusiast
Ohio
I drop the Jeep off at 4WP tomorrow. I am excited. They are installing Revolution 5.13 gears, Revolution axles front and rear, ARB lockers front and rear, ARB twin compressor and manifold, Swayloc, new brakes front and rear, and doing a CA adjustment. I can't wait to pick it up. Hopefully done by the weekend. Looking forward to taking off the hardtop and putting on the new safari top and soft doors.
MeanGreen86
Buy once, cry once
York, PA
If its not too personal can you share what you paid for it all minus the brakes and swayloc? this sounds like what I want to do.
tweezer
tweezer
Jeep Enthusiast
Ohio
I picked up the Jeep tonight after a week at the shop. Interestingly, it's no longer a 4WP but now Total Offroad. It looks like a few across the country have changed name. Anyway, I couldn't be happier with the experience. They were excited to work on an LJ and I feel good about the money spent. The 3 year warranty on all of the work certainly helps.
Holy shit do the 5.13 gears make a difference. The Jeep feels powerful again. The Swayloc and the CA alignment too. It drives/handles nicely. I will take it back in 500 miles or so for a check of everything, and they are going to redo the rocker switches for the compressor and lockers. They are ordering a new panel that will keep a stock look. I just need to find OME looking locker switches. They also threw in an air hose and connectors for tires or whatever.
This weekend I plan to wash/claybar/wax and then lose the hardtop and doors for Summer. I hope to get the Savvy front bumper installed too. i asked them to leave the stock bumper off after the Swayloc install. I am stoked and motivated for summer!
tweezer
tweezer
Jeep Enthusiast
Ohio
Weekend is not going as planned. I removed the hardtop on Friday after work but when I tried to install the new header I bought for the safari top, I discovered Bestop did not include the hardware required. Morris 4x4 is working on sending me the hardware. I then tried to put on the deck cover, but there was no way. Lol, definitely needs to be warm and sun soaked. From there, I attempted to remove my doors. LOL. No chance they are budging without some work and Kroil. That's in progress after some forum reading. Today I did install the Savvy front bumper and did a wipe down with quick detailer. Definitely digging the new front bumper and the no top look.
tweezer
tweezer
Jeep Enthusiast
Ohio
Looking good!
Now tell us how were you able to snag a Savvy bumper 😜
Thanks! Lol, I bought it last fall and am just getting to it. I grabbed a steering box and gts at the time too. The gts and BL are next on the list.
Reactions: PNW_LJ
tweezer
tweezer
Jeep Enthusiast
Ohio
Finally received the hardware to install the header for the safari top. Got it and the duster cover in place. I love the look for summer. I'm not sure what I'll do with the soft top I bought last summer, but at the time, I wanted to deviate from what I had run on all of my previous Jeeps. I guess you like what you like.
Karin and I took the day off, so after taking my 19 year old cat to the vet (relatively clean bill of health, woohoo) I swapped out the subwoofer in the Jeep. When I installed the new sound system last summer, I bought the JBL Bass Nano, which is okay and fits under the console, but doesn't do well at peak volume. I replaced it with a Kicker 10" hideaway powered sub (Kicker 46HS10) and holy shit what a difference. It thumps at peak volume and no distortion or clipping. I couldn't be happier. It doesn't fit in the console, and I looked at mounting it in the rear seat as others on the forum have done, but it didn't look like it was going to fit under the seat, so I put in the footwell behind the drivers seat. Not perfect, but it will do.
After, I went for a drive. Really happy with the new gears and brakes, though the caster is not dialed in as good as it could be. Still just a bit darty steering. I need to take it back to the shop for a recheck of all the work and will have them dial it in. I also have something leaking down on the front drive shaft. It's thin and dirty looking. Perhaps the water pump is failing? Anyway, stopped for some pics.
Once home, I installed the new headlights. I didn't go LED, was just looking for something brighter than the stock headlights. I went with KC HiLiTES H4 headlights. They are definitely brighter and look pretty sweet too compared to stock.
If tomorrow is a rainout (I have a shit ton of yard work to do) I think I will work on installing the ORO Litedots and lite'nboltz. I also need to get back to trying to get the doors off. They are super stuck.
tweezer
tweezer
Jeep Enthusiast
Ohio
Karin and I made it a 4 day weekend, so I finally finished up the ORO Litdot install. I had to cut the Exogate to fit the light on the passenger side, which I worked on over the last week or so. It was outside my wheel house but it turned out pretty okay. I cut it with an angle grinder and then spent many hours cleaning it up and sanding it with a Dremel. I touched it up with some satin spray paint. I again reinstalled the whole Exogate and finally have the tailgate aligned. It's swings freely and closes like butter.
In the process, I had been debating deleting the spare and went that route for now. I can add it back for trips and what not pretty easily, but for how I am driving the Jeep day to day, I like it. I ordered a Kentrol license plate mount with 3rd brake light and plate light this afternoon. For now, I cut down the stock license plate housing and mounted to the Exogate and used zip ties to attach the plate. I just have to limit myself to daylight. The Kentrol mount will center it up. I used some plastic inserts @Irun provided a link for to clean up the remaining nutserts. I think it turned out pretty good. I'll grab some pictures of the Litedots after dark but for now, here's how it stands.
