Two For One—A Go Fast TJ and J10 Build
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Here we go guys, finally got some TJ updates for this TJ forum!
So I used to run 2.5" 12" shocks in the rear, they were a pair of shocks I picked up used and ran as is. Most of the zinc coating was gone and my tires rub the shit out of the shocks pretty much every time I take a corner because of my excessive body roll. The 2.5's were looking pretty rough, all the COM bearings were shot and they needed a rebuild. That was like a year ago or so. Rebuilt the shocks, bought some new black top and bottom caps and eyes, sandblasted the bodies and resis and decided to try painting them with Steel-It Black. The initial thought process was the Steel-It would be durable enough to withstand the tire rubbing. A $90 paint job later with some badass looking shocks and the more dumb that idea was starting to sound, not wanting to ruin the paint on the first corner I never put them on.
Well what do you do when you want to run big ass shocks on tiny little axles? This was what I came up with. I had a pair of hard plastic dust covers from the pair of 3.0 IBP Raptor shocks I bought, but they use a weird triangle bushing lower eye to bolt the dust covers on. A few measurements and some quality time on our brand new lathe at work and these split clamps were born. They turned out awesome, a really nice snug fit on the lower eyes of the 2.5s with a matching internal groove to slip into the OD groove on the eye. Two 5/16" bolts to clamp it with three 1/4-28 holes on the OD for the dust cover to bolt up.
Got the hard work done on the lathe with a small flat milled opposite of the 5/16 holes for indexing purposes later on. Moved to the bridgeport to drill and tap the first 1/4-28 hole while indexed on the milled flat. Then I bolted up the dust cover, marked the other two holes with sharpie and eyeballed the angle on the next two holes. Not sure what the angles are, but it wasn't a nice easy 120* between holes.
Then with all the holes in place, indexed back on the milled flat again and cut in half with a big slitting saw. A little bit of deburring work and they're all finished up. I made four pairs in case I screwed them up, but I managed not to scrap anything. I did get lucky as I didn't think two much about where the last two 1/4-28 holes would land, and they are real close to breaking through where I cut them in half, but luck was on my side.
Eager to test out my idea, I made a trip up to Pcoplin's shop and got the Jeep on the lift. Had to trim the back of my Artec coil buckets just a little bit for clearance near the clamp. Got all the masking tape pulled off the shocks, and I gotta say I really love the color of the Steel-It black, seems like it has a bit of smoke or charcoal to it. Plus with the cleaned up blue hoses, these 2.5's are looking real good all blacked out. I spent a good part of the day carefully getting these shocks in, pulled springs to cycle the suspension and made some better bump stop extensions to replace my previous DOM version that used too small of tubing and cause the bump stop cups to start to bend up and around the tube. Also made some thin plastic split sleeves for the resi hose clamps, they've got a little OD groove for the clamp to seat in and snap into place nicely on one of the grooves on the resi, should keep the clamps from tearing up my paint job.
Everything fits just like it used too, the tires rub the dust covers exactly as planned and I really like the sleeper look the blacked out shocks give, almost can't even tell they are there.
Full droop
Ride height
Full articulation
And I'm happy to say that I made the 40 mile trip back home with the 2.5's on last night. Definitely got some good rubbing in taking some hard corners at 50mph. Got home, there's some rubber left on the plastic dust covers, and absolutely zero marks on the shock paint job, so it seems they were a success. Time will tell on how long the paint will hold up, but I think these should make the required touch ups a lot less frequent at the very least. I love it when one of my ideas actually works
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
I also did some other stuff on the Jeep while I was at his shop. I pulled the mini cats and gutted them, then put the exhaust back together. Have a leak at one of my Marmon flanges, gonna fix that today. It sounds pretty shitty right now and is louder than I'd like. Think I'm either going to add a small round resonator where the third cat normally is, or maybe even a second smaller round muffler in front of my flowmaster. Pretty sure my neighbors all hate me whenever I leave to go somewhere.
Also got the LSC adjusters pulled out of my front 2.0s, not my cup of tea, but I was just the test mule for some different tunes with them. I have some more surprises in store for the front shocks, hopefully the 2.0s wont be in there much longer, 13" of travel in the front is definitely too much lol.
Also working on a rear swaybar solution, as I have all of the parts for the rear antirock kit, but I don't want to drop my savvy gas tank skid to the lower setting to fit the sway bar, and I don't think I can make the arms and links live in the same space as the 2.5s and springs. Space is tight there already if you haven't noticed haha. I might have an idea though, going to check it out today and see if it is feasible.
NashvilleTJ
I miss the snow...
Nashville
Awesome machine work, Trev. And to think I knew you back when you were just a kid. I’m so proud….😢
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Haha thanks a lot, I remember spending most of the days in highschool reading yours and other build threads on JF, maybe that's why I ended up as a machinist...
Definitely not the hardest parts I've made, but those long drills and taps get the pucker factor up when that turret swings around. Really didn't want to be the first to scratch the new lathe
Reactions: NashvilleTJ
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Felt pretty slick after coming up with this one. Made the air intake the other day, not a permanent intake, but we all know how temporary goes. Was pretty floppy with everything all clamped up. Noticed my ground stud that I welded to the inner fender happened to line up almost perfect with the filter.
One big chunk of nylon later and the air intake is nice and stable. The jam nut to lock it in place is missing in the picture. Probably gonna turn some more off the OD so it's not quite so bulky.
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
More truck stuff
The factory 45* water pump neck on the LS wasn't going to work with my air intake location. Found a short 90* bend piece of 1.5" stainless on McMaster. Pulled the factory neck out of the water pump, cut off the press fit end and the barbed hose end and persuaded my coworker to tig it all together for me. Pressed it back into the housing with some loctite 680 bearing retainer. Hopefully it doesn't leak.
Also found this hose while wandering through napa, looks pretty promising, but I need to wait 24 hrs for the loctite to cure before I start messing with it. Gonna be real happy if I can make this hose work, was already able to find an off the shelf hose for the lower hose, but fitting 1.5" onto a 1.75" barb wasn't easy lol.
Reactions: Bud125
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
The 100* weather hasn't been much fun, but I'm still getting stuff done.
Got my hoses routed most of the way for the transmission cooler. Went with some .5" ID derale hose, about 25' to get there and back. Just made some quick sheet metal brackets I welded to the frame like I did with the hard lines for the fuel. Clamps aren't as fancy though, just a 3/8" nut welded to the back of the bracket and some double hose rubber clamps.
I might need to add two more brackets to break up two of the longer spans, the hoses are a bit floppy. Not sure how much I need to worry about them rubbing each other, maybe I need to sleeve them with something or make some rubber separators I can put in the clamps or zip tie the hoses too.
Reactions: zebra12 and Bud125
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Decided to see if I could get these bolted in. They're some weird 10" 2.5 single tube compression bypasses with a top feed reservoir. Paid more than I probably should've a long time ago and finally got around to messing with them. Was happily surprised to pull them apart and find a 1" spacer between the piston and bearing block. I decided to go ahead and pull that out so now they are 11" 2.5 bypasses. The compressed length on these is 19.4" and the 13" 2.0's that are currently in the front are 19.1", so they are really close.
Unfortunately the drivers side didn't quite fit. At almost full articulation and a hard left turn the caliper bleeder screw and the brake line starts to get into the shock body.
Ive got a plan for tomorrow to hack off my old ugly lower shock tabs, and weld on some new ones slightly lower and about 1.5" further towards the rear to try and sneak that bleeder screw around the shock body.
Also going to probably swap my brake lines over to an AN hose with a banjo adapter to have less hardline poking off the side of the caliper to avoid the shock.
Then the resis will be mounted next to the shock nearly vertical in the inner fender. I'll have to have some super short double 90* hoses made for the resis.
All in all they fit pretty well, some tire rubbage but that's no skin off my back. The 11" of travel will be much better fit than 13" I have now, the track bar pulls the axle so far driver side it's not even funny. I think the first 2-3" of up travel from normal ride height will be in my bypass zone, so looking forward to playing with that and seeing what it can do at the dunes this summer.
Full bump in the front
Reactions: 02GreenTJ
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Got the 2.5 mounts finished up today. Just need to make resi mounts on the inner fender and get some hoses figured out.
Ended up hacking off my old lower mounts. I needed to move the lower mounts back ~1.5". I ended up using some of that 6"x3"x.250" tubing I bought from work. Its internal radius was the same as the outside corner of the currie CA mount. Just shaped it around the bolt and tried to clean it up a bit. Used some .25" tabs that I had made a bunch of a couple years ago. Nothing too pretty, but much better than what was there before.
Unfortunately I screwed up the drivers side a tiny bit. At full lock left, full articulation, the body of the caliper just barely scrapes the shock. Luckily my brake pads and rotors are pretty worn, so once I replace those in a week or so, I should have maybe an 1/8" of clearance for a while. Could also cheat the axle over a tiny bit with the track bar. That original metalcloak heim should probably be replaced anyways since it's from 2016 lol
So close, yet so far...
It was also so damn hot out that my head spontaneously combusted while I was welding in the driver side mount, lost a good chunk of hair to that one...
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Just realized that I switched the lower mounts from 1.25" width to 1.5" when I made the new ones. I'll just make some custom spacers for the shock eye, a long and a short to shift the shock eye towards the rear maybe 3/16". Easy peasy
Reactions: Bud125
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Exciting stuff. Got the bypasses finally put on yesterday. Did a full rebuild on both and had to get the resi mounts in. Made my custom lower spacers to cheat the shock back an .125". After the brake job I've got coming up I should have plenty of room. Swapped out the factory bump jounces for some stiffer energy suspension ones I cut down to 1" long too, so that should help a bit on the hard hits.
With the shorter shocks I was able to go to the second stiffest hole on the antirock. Definitely felt a lot better on the ride home as far as body roll, though I had the bypass tube completely closed off so that probably helped some too since they have a good bit of valving and the low flow pistons.
Found some cool conduit hangers that I used as resi clamps, thought they worked pretty slick. Part number 454010 at platt electric for a 2.5 resi. They flip open 180* when the bolt is undone and have a rubber insulator on the inside of the clamp. Was only $4.50 for four of them too.
Only very slight rubbage at full turn full articulation, shouldn't be a problem I don't think. The 2.5's raised me up .5" in the front vs the old 2.0's, I've got an extra .5" isolator on the springs I may pull out.
Pretty sure my upper bumpstop tower is bent on both sides from hard hits, the whole coil bucket may be bent. Eventually I'd like to work some hydro bumps in front and rear, with them inside the coil spring. That'll be a good bit of work, and require whole new coil buckets and maybe shock towers in the front. I may try to lower the ride height an inch front and rear when I do that, but that'll be a ways away. Just thinking out loud.
Gonna plan a sand dune trip soon to test these bad boys out.
Trevlaw
Trevlaw
Sketchy Machinist
Corvallis, OR
Did you build your own hose for the shocks, Trev?
No those are the hoses that came with them. Got lucky and they ended up being the perfect length for what I needed after adding the two 90's at the resi side. Would've preferred a single 180*, but those were $35 a piece and I got all the 90s for $20 total.
I actually didn't notice until pcoplin pointed it out, but someone did make the hoses previously with the reusable fittings. After that I noticed my rear hoses are the same exact thing, and I guess two different people I bought the pairs of shocks from also went to the next size up, -10 hoses on all 4 shocks, instead of the usual -8 for the 2.5s. At least they match, and I like the blue hoses, kind of goes with the jeep.
