^ I'm not sure if you wrote something, but I don't see it.
The combo won't help your driveshaft, but the MML alone will. I still think doing both is a good thing, especially to fit 35's if you're going with a 4" Currie/Savvy short arm. But a lot of people don't like the look of a body lift, so if you stay at 4" you'll be golden for 33's and the MML will help the driveline angle.
If you get above 33's you might think hard about going with a 17" wheel. The reason is you get the bigger brake kit from BMBrakes. You'll want to stop those bigger tires and the bigger brake kit will do it. As for myself, I'll probably just stay with 33's and get the brake pads. Saves lots of coin and I can go anywhere in WA I think. Also have those 33x10.5r15 tire choices as well as 33x12.5r15.
I don't care for bodylifts either, but it sounds like it'll be useful in making the motor mount work with the radiator? No, if I did 33s, I'd prefer no body lift. But if it helps with the radiator and the tummy tuck that I will do someday, though not necessarily with this project, I'll end up just doing it. Also because I'll be doing the gas tank fix, and I only wanna do that once.
I'd rather do 16s than 17s. There is a 34x11.5R17 (285x75R17) that is tempting, though. I did consider going with the 17s for the sake of the larger brakes. But I like having more sidewall and less expensive rims and tires. But, it's still a posability.
I would do a lot more research before you pull the trigger on anything. Use reliable sources for your research. For example, one thing I’ve found is that Facebook groups are full of opinionated people who don’t really understand what they are saying (IE I ran 37’s on stock axles /gears for years and never had a problem). The forums are usually more reliable than some random guy on Facebook.
I would also try to understand what the long term costs associated with your end goal are and compare different routes to get there. I’ve been lucky in that very few things I’ve put on have needed to be removed for future upgrades. Typically, the cheapest way to do things is all at once. If you really want to end up with 35’s, lockers, gears, a TT, axle shafts, etc... the cheapest way to get there is to do it all at once. Buying parts twice sucks and can make your long term cost much higher than it needs to be.
I would not worry about 12.5 versus 11.5 versus 10.5 in the snow and rain. I drove around with 12.5 wides on terrible snowy / icey roads for years with no problem. I would assume the roads you have in Washington would be much better than what I was dealing with just due to the fact that you’re in a more populated area than I was. If you remember that you’re driving a lifted Jeep on mud tires through snow and drive accordingly, you’ll be 100% fine.
I haven't asked much on facebook, only the LJ group about needing a new driveshaft with 4" of lift. I got mixed responses.
That's why the build is getting so pricey, to be honest. I thought just do 33s without regearing, but once I realized I probably will have to regear, figured I'd might as well gear for and get 35s and chromollys. And while I'm in there, might as well add the lockers. Save something like $1K in labor in the future. That's why, if I can get by without a new driveshaft on my LJ, I'll hold off on the tummy tuck for now. If not, might as well only get the driveshaft once. I'm only a little hesitant on building up my axles if I wanna swap them out. But... there's an XJ in the family I can donate my axles to in the future, if I do the swap. I'll likely do the shafts as well with 33s, just cuz I wanna make it stronger.
I just worry a bit with road traction, cuz I already slip a bit with my 9.5's. But I see so many 12.5's around here anyway. I figured tall and thin would help with deeper snow, and help handling and what little MPG can be salvaged on the street.
Something to think about, If you do your research you'll find a huge amount of differences with so-called tummy tucks. Some will give you a totally flat to the chassis result others will give you a better shaped skid with maybe a small amount of lift.
The higher you make the "tummy tuck" the more issues you'll run into. I'd suggest you sit down, plan the total build based on required tire size. Then work your way through suspension lift and then make tummy tuck decisions based on that.
I guess I'd go as tall as possible on the tummy tuck, without causing too much of a headache. So long as I can get by with my current driveshaft, I think I've made up my mind and I'll hold off on it for now. And you're right; gotta commit to a tire size and stick with it.
Another option would be to buy the lift first and space the t-case down while you're saving/planning for your tummy tuck. That way you don't have to wait to do it all at once and you would only need to replace the driveshaft once. My LJR currently has a 3.5" lift from rock krawler with the t-case drop and stock driveshaft. I don't like it, but I can still use it. I've had the TT from undercover fab, a 3.5" short arm kit from metal cloak, spring relocation brackets and outboard shock kit sitting in a pretty pile waiting to be installed for quite a while. My plan is to do the suspension and TT at the same time so I can measure for the drive shaft. But also tackle the outboard rears at the same time. Waiting has been agony but there is a convenience to doing it all at once. I saved up, bought a part. Saved up, bought something else etc. over a couple years. THE STRUGGLE IS REAL! But Im getting really close now. The trick is to have a plan and stick to it!
Did you try to run your LJR without the transfer case drop? Or did you it on right away? I'd like to avoid dropping it, though it would still be a net gain with the tires and lift.
I've had my LJ for 6 years now, and all I've done is a new top. After mine got cut open. But I'm getting anxious now!
Thanks for all of the help so far you guys, I really do appreciate it. At this point, I'm leaning towards not doing the tummy tuck yet, but setting myself up for it with the adjustable control arms and body lift. The lockers will depend on the budget. If I can't afford them just yet, I'll have to deal with double labor costs in the future. But if my stock driveshaft doesn't work, I'll have to decide from there if I can do the full tummy tuck, or just have to pay for two driveshafts. We'll see.
