quite a bit. you can have a normal conversation while driving down the freeway at 70How much of a difference did the dynamat make?
it dampens a lot of the road noise
After doing a bit of research, ordered some 20/80 tubing and fittings, for both mine and my sons jeep. assembled it and set up rivnuts for the molle mounting. it came already powder coated and assembled rock solid. bolted it to the shell using one of the mounting bolts for the hard topin an effort to add more storage, added some molle storage to the driver side rear.
it is in Solid and it doesn't rattle. I used aluminum angle iron for the frame.
I like the look from the inside but I don't like the look through the window so I am
going to redo it with square tube.
