More progress on my sanden OBA project. I dont know what I did earlier on mounting this but it doesn't quite fit. Width wise they mount fine but the compressor is just a hair to long. What I did to fix this (and it is not perfect) is drill out the compressor mounting holes carefully with a 1/2" bit
I can get three bolts on it now but the rear corner is still a good 1/4" off. I need to think about how to fix that.
The fittings off the compressor are flare fittings. Which made things a little complicated, luckily I was told about swivels which are gas fittings. These things run about $12 a piece at the ACE hardware
Here is my test fit
Intake side with Speedaire oiler. Lesson learned, buy an oiler with 1/4 inlets. Sizing down from 3/8" took a number of fittings. Not sure how long the intake nipple will last, it's simply a plastic 90 degree that I screwed into place (I know, I need a clamp there still).
Discharge side. I'm not sure how these will hold overtime. My connections are long which is a lot of leverage at the compressor fitting
Mounted the manifold on the inner fender. This is pretty self explanatory. Inlet, pressure release (175psi), pressure switch (90/120 psi) and the outlet. I got the 4 hole manifold incase I add a rear outlet.
And the fitting for my air hose will be on the bumper. I plan to either drill thru the winch plate and mount it vertical, or weld a piece on and mount to that. Still need to button it up.
Not quite finished, but its plumbed and ready to hopefully finish tomorrow.
