u joint question
Kevin E
Lifetime Supporting Member
Wharton, TX
Does the Dana 44 front and rear use the same u-joints as the Dana 30/35? Trying to get all my bases covered for this weekend axle swap
If you're talking Rubicon Dana 44 axles, no they use different driveshaft u-joints. Rubicon driveshaft u-joints also vary between the 2003-2004 and the 2005-2006 models. The axle shaft u-joints are the same for the Dana 30/Dana 44.
Thanks Jerry. I guess I need to be a LOT more specific now. Yea my new axles are 2006 Rubicon Dana 44's but you already knew that.LOl
That's a great chart to have. So these would work? Since I have a 4' suspension lift my driveshafts should be good also? Hopefully?
1330 Cross Over U-Joint
