Hey guys. For a while my Double Cardan rear driveshaft looks like its been slinging grease; its all over the bottom of the body tub and exhaust. If I keep it lubed should I be concerned? Or is it time for new joints?
Yes they're all the same, and front and rear driveshafts use the same u-joints.I found some on RockAuto.com, but it says it's for the front driveshaft on a canadian jeep. Are they all the same?
Thanks you guys!! It's an aftermarket shaft I put in years ago after a SYE kit. Y'all have any links on how to ID an u joint?
I'd bet big $$$ it is the normal/usual/regular 1310 size u-joint. This is the one I'd go for... https://www.amazon.com/dp/B009X1X91O/?tag=wranglerorg-20 which is the same one I recommended at the top of this thread.Thanks you guys!! It's an aftermarket shaft I put in years ago after a SYE kit. Y'all have any links on how to ID an u joint?
One problem that new u-joint installers commonly cause is the u-joint to bind, caused by seating the bearing caps in a little too far/hard. That then presses on the u-joint body which binds it.
An easy way to relieve that binding is to use a BFH (big effing hammer) on the yoke that holds the u-joint to use inertia to drive the bearing cap back outward against the clips holding the bearing cap in place. Several mighty whacks on both sides of the yoke as shown is enough to relieve that most common type of u-joint binding.
