Underbody wash / detail
AndyG
TJ Guru
Lifetime Supporting Member
Alabama
This nailed it. I spend 6 - 8 hours wheeling, then two to three times that bringing the Jeep back to my happy state! :(
I've got a buddy and every time he goes with me he wants to get into some mud hole and we end up cleaning up for 3 hours for 25 minutes of fun...
I don't go out looking for mud... But that's just part of it.
Reactions: Irun
Moab
El Segundo, California
I'm tm not picking on you but accumulate what's been commented in several posts..
I had experience in the chemical and cleaning industry...
Acidic cleaners are the wrong pH for dirt and are going to do nothing but possibly activate or worsen rust.
Purple Power as far as the cleaner itself is very high on the alkalinity scale because it has sodium hydroxide... This is also known as caustic soda. It's effective but if it's used enough it will eat off paint finishes and attack metals. purple Power sells a wash and wax product that is economical and one of the better washing wax products I've ever used for your exterior paint finish.
Simple Green is probably one of the best cleaners ever put on the market for repeated use...what will make simple green work the best is to put it on and give it 20 or 30 minutes to work.
Heat always makes a difference in the cleaning process...even a scrub brush dipped in hot water will clean far better than one in cold water.
A water hose hooked up to a hot water spigot is amazing.
Heat and agitation are your two biggest factors in cleaning... Pressure is a two-headed sword ... It can get bad things out of nooks and crannies and it can get good things out like Grease.
Also any cleaner needs to be rinsed thoroughly.. Some cleaners will attack bushings, gaskets and o-rings.
Also taking the vehicle for a good drive before you put it in a garage is a good idea if you want to keep ahead on the battle against corrosion.
I was referring to finding a steam cleaning service.
ejay
ejay
Freedom
I've seen wash specific to underbody but it looks like it's got an oil in it which just gives the appearance of a nice look for a little. I imagine until it collects every grain of sand and dirt while you drive. Anybody have any luck with such products?
Mr. Bills
Raconteur Emeritus
Area Code 530
I have also herd that people use a lawn sprinkler and let it run for awhile, I have never tried it but is sounds like it could work.
Use one of these.
Its not high pressure so one must run the sprinkler long enough to soften the crud - long enough to drink a beer maybe two - then a regular hose with high pressure nozzle will do the rest.
Reactions: MountaineerTom
ejay
ejay
Freedom
So Purple Power if you're going to rinse it off after 10 minutes. Simple Green if you've got some time and a brush. Any other Auto Store products?
