I assume these would be considered baffles and not brackets?
SO either I find brackets for a round speakers in the front. Or just replace them with ovals and use the original bracket. But stuff poly behind the speakers?
there’s too much open space in the dash to stuff polyfill in, so whichever speaker you get be sure you can get a baffle. That is assuming you want to hear them at all, the acoustics of the TJ dash are non-existent.
So is the easiest solution to buy oval speakers for the front and use those baffles made out of matting shown above? I'm not hearing a simple solution for putting round speakers in the front.
This is what I ended up doing. Bought all four round speakers and the baffles. Waiting on all items to arrive tomorrow so I can install them.I bought the same polks for front and rear (DB522) with these https://www.amazon.com/dp/B00T1AB28Y/?tag=wranglerorg-20
it’s expensive but after running without any baffles vs those - worlds of difference. I can’t speak to the foam baffles.
Do you still have this current setup?I see a lot of questions about how to get a better sound system from your Jeep Wrangler TJ. People will often dismiss the TJ as being a vehicle with poor sound dynamics to begin with, and while this is true to some degree, I can tell you that the sound system I have in my 2005 TJ Rubicon is absolutely killer, and it didn't break the bank either!
At 65+ on the highway with the doors off and the top off, I can hear the sound loud and clear without any issue at all. I have my subwoofer volume set at 6 (out of 12) and the subwoofer volume on the amp only turned to half way. Yet the bass still kicks like you wouldn't believe!
Here's what I am using for my setup:
Some of the components I bought from Crutchfield, while others I got from Amazon.
- Kenwood KMM-BT322 Digital Media Receiver
- Kicker CompRT 6.75" Subwoofer
- Kicker PXA200 Amp
- Polk Audio DB522 Speakers (for rear sound bar speakers)
- Polk Audo DB462 Speakers (for front speakers)
- Polyfil Stuffing (for rear sound bar speakers)
But that's it, literally. I mounted the amp underneath the front center console (it's a very tiny amp) and the subwoofer is mounted in place of the factory subwoofer (which some TJs came with). The amp powers the subwoofer alone, and the speakers are driven off the head unit.
This sound system is no joke, I mean it. I was expecting it to be a little better than stock, but I wasn't expecting it to be this good. If you crank the volume all the way up to 35 (the highest it goes), it's deafening.
I highly recommend this setup to anyone who is looking to improve the sound in their TJ without breaking the bank. This is all you'll need, I can promise you that.
So while this isn't a "how-to" guide in terms of installing it, I feel like this is a fantastic setup at a price that won't leave you broke.
Hey was just wondering if that is a double din stereo head unit. If so where did you find the dash bezzle that is silver that fits it? ThanksI've got the Sony system installed. Still tweaking the settings, but I'm already liking it better than I did the Kenwood unit. Plus, it's got big buttons!
Hey guys, I found this thread about a month ago and purchased the exact list of components from the initial post (for his Christmas present) but I did not get the head unit. My sons jeep came with a boss aftermarket head unit that I will be using. His jeep does have the factory installed subwoofer in the armrest. I believe I can handle swapping out the front and sound bar speakers and probably even the sub. My question is, how do I wire up the amp from the head unit and to the sub. I may have overlooked The information in this thread. I have never worked on stereo components other than swapping out a pair of speakers
Yes, the stock sub is working now, I was just going to replace it with the aftermarket one. I guess my question is where do I wire in the amp? I am assuming it is wired between the head unit and subwoofer so I was wondering about the wiringIs the stock sub working now? If so, no rewiring should be necessary if you're using it.
I'm still running the stock sub in the console with my aftermarket head unit and aftermarket speakers in the dash and roll bar sound pods. I just used the wire harness adapter that came with the install kit which connects to the stock speaker and sub wiring. Both aftermarket head units I've used have had the subwoofer working great without having to wire it separately.
The harness adapters are easy enough to find. Even WalMart has them in their automotive section if you don't want to mess with an online purchase. Just maker sure it's for your year model Jeep and wire it up to the headunit, then plug it into the stock connector.
It's pretty simple. The Kicker amp is low enough draw (15A) that you can use an add-a-circuit in the fuse box behind the glovebox rather than going directly to the battery. I mounted it on the firewall near the fusebox. Wires to the sub run thru the center console. And then RCA wires to the head unit. Done.Yes, the stock sub is working now, I was just going to replace it with the aftermarket one. I guess my question is where do I wire in the amp? I am assuming it is wired between the head unit and subwoofer so I was wondering about the wiring
OK, I think that clears it up. I’m sure it will be easier to understand once I actually tear things apart to see yet. Does it matter which fuse I connect the add a fuse to? Does it need to be something controlled by the key?It's pretty simple. The Kicker amp is low enough draw (15A) that you can use an add-a-circuit in the fuse box behind the glovebox rather than going directly to the battery. I mounted it on the firewall near the fusebox. Wires to the sub run thru the center console. And then RCA wires to the head unit. Done.
I used the fuse for the rear window washer/wiper since I only have a soft top. Or there is a fuse for the factory sub amp too. Both are on/off with the key.OK, I think that clears it up. I’m sure it will be easier to understand once I actually tear things apart to see yet. Does it matter which fuse I connect the add a fuse to? Does it need to be something controlled by the key?
