1. Want to have your TJ featured as the August 2018 "Ride of the Month"? The winner will receive a $200 gift card from Metalcloak! Click here to submit a photo of your TJ. Submissions are accepted until July 20th!
    Dismiss Notice
USB power
Discussion in 'TJ General Discussion' started by StG58, Oct 15, 2017.
  1. TJScott
    TJScott TJ Enthusiast
    Feb 4, 2017
    171
    181
    Palmdale, CA, United States
    You are absolutely correct. Get 2.1 amp on both ports if possible. It will just charge your phone faster and it will charge your tablet properly. I use 2.1 or 2.4 amp all the time on my phone. My portable device battery comes with 2.1 and 2.4 amp ports for charging on the fly.
    StG58 and JeepNWilly like this.
  2. Redbeard
    Redbeard New Member
    Feb 1, 2018
    3
    0
    Olympia, WA, United States
    I installed this in my 05 TJ last night, and this morning my battery was dead. Any suggestions?
  3. FireJeep
    FireJeep TJ Enthusiast
    Jan 4, 2018
    132
    111
    Virginia
    Really?! I would not have thought it would kill a vehicle battery..... How did you have it wired? Is there an LED on the receptacle that is always lit? Did you wire this to the "always hot" lead?
  4. Redbeard
    Redbeard New Member
    Feb 1, 2018
    3
    0
    Yeah, so I simply cut the wires from the existing cigarette lighter and matched positive to positive and neg to neg. reassembled dash and tested the plug. Went to bed and woke up to a dead battery.
    It does have a red LED light that stays illuminated even with the keys out. PO must of re-wired off the always hot lead. Yay me
  5. Rob5589
    Rob5589 Rust•eze Bumper Ointment certified dealer
    Aug 29, 2016
    4,646
    4,188
    W Sacramento, Kalifornia
    I wired mine to the non hot side, only on when key one. I think the cig lighter is always hot.
  6. Redbeard
    Redbeard New Member
    Feb 1, 2018
    3
    0
    I’ll tear it apart and re-wire it tonight and let you know.
  7. TJScott
    Feb 4, 2017
    171
    181
    That LED shouldn’t pull enough current to kill a battery over night. Perhaps there is something else going on there?
  8. ac_
    ac_ zombicon
    Jun 15, 2017
    2,240
    2,082
    AZ, United States
    Already have one but here is mine comes with a volt meter:
    Equilibrium31 and FireJeep like this.
  9. FireJeep
    Jan 4, 2018
    132
    111
    Virginia
    What transfer case shifter set up do you have? Do you like it?
    ac_ and JamesAndTheSahara like this.
  10. ac_
    ac_ zombicon
    Jun 15, 2017
    2,240
    2,082
    AZ, United States
    Kiwi TJ likes this.
  11. ac_
    ac_ zombicon
    Jun 15, 2017
    2,240
    2,082
    AZ, United States
    Here is another angle:
    Kiwi TJ likes this.
  12. Kiwi TJ
    Kiwi TJ A naked man fears no pickpockets
    May 3, 2016
    2,474
    3,400
    Auckland New Zealand
    Love that old school look mate.... reminds me of the Hurst Lightning rod shifters in the early 80's...lol
    ac_ likes this.
  13. ac_
    ac_ zombicon
    Jun 15, 2017
    2,240
    2,082
    AZ, United States
    I remember having an old 72 Scout that had the same type of shifters, and of course the old-school CJ's except they had more sticks haha.
    Kiwi TJ likes this.
  14. GreaseMonkey
    GreaseMonkey New Member
    Jun 30, 2018
    2
    2
    Spanaway
    JeepNWilly likes this.
  15. TJ4Jim
    TJ4Jim TJ Enthusiast
    Dec 9, 2015
    986
    678
    Brookings, Oregon
    I have the 2.1 amp usb on my Harley and it will not maintain my GPS operation so I just installed a 3.1 amp on my Indian, we will see how that works out.
    KCsTJ likes this.
  16. RussTJ
    RussTJ TJ Enthusiast
    Nov 22, 2017
    178
    197
    Bridgewater, MA, USA
    @ac_ Did you replace the ashtray with another bank of switches? If so, were there any modifications needed?
    #36 RussTJ, Jul 4, 2018
    ac_ likes this.
  17. ac_
    ac_ zombicon
    Jun 15, 2017
    2,240
    2,082
    AZ, United States
    Yes and yes.
    I ordered another blank from ebay for like 20 bucks. I had to do some mods, but not hard if you have a dremel.
    I did mine kind of like this. On the passenger side, I drilled a hole in the plastic, and slipped in a speed nut then made an aluminum angle and attached it to the modded switch panel so it would screw in on both sides. If I am ever in there I will take a picture of what I am talking about.
    See if I can explain that better:
    So on the original switch panel you have to cut the part that screws onto the dash and then bolt the new switch panel to the old one. I just bolted some angle on the opposite end of the new panel and attached a speed clip in the dash so it would bolt on both sides of the switch panel. I hope that makes sense. I don't believe they do this in this link. Or maybe they do, I didn't really see this link till after I did mine.
    But basically here is a link that does what I did:
    https://wranglertjforum.com/threads/add-another-dash-switch-panel.7588/
  18. RussTJ
    Nov 22, 2017
    178
    197
    Thanks for your help. The ashtray is wasted space on mine too and I wanted to see what others had done to theirs.
    ac_ likes this.
  19. ac_
    ac_ zombicon
    Jun 15, 2017
    2,240
    2,082
    AZ, United States
    No problem glad to help. Let me know if you have any questions, or need any help.
  20. fuse
    fuse Member
    Jun 5, 2018
    40
    24
    San Diego, CA
    If you're charging larger phones or tablets, you may want to look into USB adapters that support Qualcomm's Quick Charge, or USB Power Delivery (USB-PD). These newer specs for USB charging can deliver up to 5A of power, which can quickly charge a larger phone or tablet.
    I went the cheap route and just dropped a cheap USB charger with Qualcomm's Quick Charge 3.0 into the cigar lighter. It puts out 3.0A on each of two USB ports. That happens to be more than enough for the phone I use for audio and navigation.
    If you're using a larger tablet, that extra power on the USB port could come in handy.
    ac_ likes this.
Share This Page
