I got to thinking this morning over my cup of coffee. Just because I have been driving 4x4's since Nixon was president of the US doesn't mean that I know how and when to correctly use the magic lever. Owner's manuals are pretty vague about the whole thing, and cover the basics only. Don't engage four wheel drive on a hard surface, engage 4 high at a certain speed, come to a stop before engaging 4 lo, etc. Then there is the whole locker issue. @Jerry Bransford has a really good thread on the how's of a locker, but what about the whens and whys? Then there is the selectable vs. full time locker thing. I've had a couple of 4x4's with full time lockers, one Detroit and one GM Corporate come to mind, but when you have one or two magic buttons to go along with your magic lever it greatly increases your options. With all of those options, how do you decide what's most appropriate and when?
For instance, with my truck with the Detroit in the rear and 33x12.50's on it, I would lock the hubs when I thought that going into 4x4 was going to be required, but not pull the magic lever until the wheels started spinning. On the Suburban with 255-85R16 mud tires, the magic button doesn't get pushed until traction is lost. Never aired down any of those. Same deal with the XJ's - loose traction and pull the handle.
Now with the TJ and a way to air the tires back up there are more options available. For example, I air down and put it in 4 hi when I know I'm jumping out onto the hard sand, 4 lo when the sand is soft. Snow? 4 hi. Rough, muddy terrain? 4 lo.
What's everybody else do? How do you use the various levers and buttons to get from point A to point B in various terrains and conditions?
