Vacuum reservoir replacement?
jhetcel23TJ
Michigan
So in tracing a vacuum leak I disconnected the vacuum reservoir (#5 in the picture below), when giving it a shake there is a rattle coming from inside the reservoir box. Is there a way to test that the reservoir is working properly? What does the reservoir do exactly? And where can I find a replacement if needed?
2003 Jeep TJ, 4.0 I-6.
pagrey
Los Angeles, CA, USA
Turn the Jeep off, wait a few minutes and then turn the HVAC controls to another setting and see if it still operates. If the reservoir is working it will still operate the vents, if it is leaking they won't work.
It's just an empty container to "store" vacuum.
Jerry Bransford
TJ Guru
Escondido California
Daryl
2004 Rubicon
Earth 🌎
Reactions: pagrey
pagrey
There has been a check valve either on or inside every vacuum reservoir cannister I have ever seen.
The black object on top of this cannister is its check valve... https://www.jegs.com/i/JEGS/555/63010/10002/-1?gclid=Cj0KCQjw4s7qBRCzARIsAImcAxaI_9Et25mdjFM-RKCVmSQ1HgsntdBmGKcw_cGVu7fGEFmTU1gPcKIaAgYWEALw_wcB
That reservoir has two hoses, ours has one. The check valve is in the vacuum line by the master cylinder.
With a single line it would not work with a check valve.
Reactions: K0LCB and Daryl
jhetcel23TJ
jhetcel23TJ
Michigan
Well, tested HVAC controls and works just fine. Guess it doesn't need replacement and not the source of my leak.
Reactions: pagrey
Daryl
2004 Rubicon
Earth 🌎
Do you have access to a mity vac? If not, see if you can borrow one from AutoZone. That way you can pull a vacuum on each component to find the leak.
HTOMT 2 in 1 Brake Bleeder Kit Hand held Vacuum Pump Test Set for Automotive with Sponge Protected Case,Adapters,One-Man Brake and Clutch Bleeding System https://www.amazon.com/dp/B07471TKRF/?tag=wranglerorg-20
Reactions: K0LCB
Dr G
NorCal
So I have a similar issue on mine. I have a '97 TJ with the 2.5L 4-cylinder. For a long time (years) when ever I fire up the Jeep for the first time it will idle fine.
After several minutes it will stutter and almost stall before revving up. During this process I can hear a sound like a chamber filling up. After that is seems to be fine.
If I start driving right away after starting the engine, then I will have a similar stutter and almost stall, then its fine. In this scenario the stutter/almost stall seems to occur once I go over 5-10 mph.
I think this has something to do with the vacuum reservoir under the passenger fender, or a valve of some kind on the manifold side.
If anyone has any ideas I'd love to hear about it!
Thanks!
Ian in NorCal
