Okay, so I spent the weekend doing maintenance and repairs on four different vehicles this weekend, one of them being my wife's '96 XJ with a 4.0 in it. Being that it and our little Mazda Protégé both use 10W-30, and I had the full synthetic Mobil -1 on hand, that's what I used in the Jeep. When I went to park the rig after I was done, I could hear valve train clatter that I have never noticed before. I immediately double-checked the oil level (full), and confirmed I had used the 10W-30 oil, and not something else by mistake. I had my wife come out and listen to it with the hood open. I explained what I was hearing, and she asked "The noise that makes it sound like a diesel?" Perfect description! It clatters like a diesel at about 1,200-1,800 rpms. After that, fan and exhaust noise drown out anything else I can easily identify. The clatter is not wicked-loud, or anything...just sounds "sloppy", like everything on the top end has a bit too much clearance.
The rig has 170,500 miles on it. When I replaced the valve cover gasket some time ago, I was impressed with how clean the valve train was (no sludge or such). It is not a knocking sound, nor is it a lifter tick. I've only ever had one vehicle with piston slap, so I'm not real experienced with that issue, but I can say it does not sound like what my other rig sounded like, so I don't believe it's piston slap. The oil pressure gauge has never been accurate (will read 40 psi, then jump up to pegged-out, then back down to 40 psi, etc). I replaced the sending unit once, but it made no difference. I'm thinking I will install an aftermarket system so I can at least see what we're really running.
So, this is either a new issue that has just arisen, or it is something that started happening a while ago, and my wife never noticed it (her hearing isn't stellar). I don't drive the rig, so I just don't know if this started some time ago, or not. If it is a new issue, could this be the result of using a full synthetic oil instead of the conventional dino oil I've always used? I've read some things online saying it's possible, and an equal number of folks saying it's not. All I know is this is the first time I've used synthetic in it. As it stands now, I'm going to have my wife drive the Mazda this week, and I'm going to change the oil again next week to conventional. In the meantime, I would very much like to hear from you folks on your thoughts on the issue.
Thanks in advance for your assistance.
Regards, Squatch
Regards, Squatch
