Hey y'all,
I've read tons on this site about solutions, but I'm still not clear about it.
My 2000 4.0L Sahara automatic drove flawlessly. I had a local shop install RC longer springs and new shocks for a 2" lift. They also mounted 32" X 11.5" Cooper Discoverer AT3 XLT tires on 15x8 rims. The reason I bought that kit is because Rough Country and all of the reviews said there was no need for any modifications.
When I picked it up, the mechanic immediately told me that I needed to get extended sway bar links because they were now so tight, that I was missing a hold-down clip at the drivers side front coil, and that I should have provided them with pads to set the coils on because they'll end up squeaking.
Driving away I noticed a vibration around 25-35 mph that would only happen when I'm accelerating. My research points to the rear driveshaft angle. I don't want to lower the transfer case with washers, so I'm willing to install the 1" MML. I'm hoping someone can tell me if I'll have enough clearance to install this without a body lift, and if I'll only need to adjust the fan shroud and nothing else.
Thanks!
Thanks!
