Oh you guys would hate brown dog then(lol)I’m in the same boat, and I’ve changed many of the sensors that can cause idle problems.
I hope to remove the idle vibes by raising the idle (when AC is on or in reverse/neutral) with the HPtuners.
Yes, i went with blocks and oem mounts.Oh you guys would hate brown dog then(lol)
Yes oe mounts are made to move around in a cage type holder,I should have went with jus the blocks too.I’m Shur if a mopar trans mount were available,it would still have to have some breaking time tooYes, i went with blocks and oem mounts.
I only have this issue in idle (when the AC is on or when idling in Drive/Reverse).
Well, I can't install my Mopar transmission mount because I have the Savvy TT installed.Yes oe mounts are made to move around in a cage type holder,I should have went with jus the blocks too.I’m Shur if a mopar trans mount were available,it would still have to have some breaking time too
That’s weird,I was able to use my factory mount with UCF t/tWell, I can't install my Mopar transmission mount because I have the Savvy TT installed.
My idle goes to hell just by turning the AC on. I'm not going to blame the Savvy TT for that even though it might not hide the vibes as well as the stock mount.
I changed plugs and multiple sensors, but nothing changed. My engine idles fine until the extra load is added. The RPMs drop when the AC is on. That seems backwards to me.
It's been a few years, do you still have this problem or where you able to get it resolved? I too only have the vibration when the transmission is in drive or reverse and only at idle. I am leaning towards blaming my bombproof rubber motor mounts but I see you reported the same vibration with OEM motor mounts so it has me thinking.
