I'm still battling my vibes as well. Been 2 years now since the re-gear, and no resolution. I have a theory based on harmonics. I have the opposite problem. I pull the rear drive shaft and run in 4 hi with just the front drive shaft the vibes all be go away. Pull the front drive shaft and run just the rear, vibes come back. Try playing with your rear pinion angle some more. Don't be afraid to go below, or above parallel with the angles. I've done a series of rear pinion angle adjustments all the way to -5.0* lower pinion angle with no change. There is some discussion to the cut of gears having some input to this harmonic. I know this doesn't help your situation, but you are not alone in this battle.
