I'm getting vibrations between 20-40mph in 2-3 gear dash shakes some then smooth's out till I go into 5th gear then there is more vibrations just not as bad if I down to shift to 4th it goes away. Please help. It's not in the steering.
+1 on tire balance. TJ tires need to be balanced perfectly or you're going to get vibrations. You really need to find a tire shop that has a technician who is experienced in balancing off road tires. A basic spin balance is fine. The key is to have the tech take the time to get the correct amount of weight in exactly the right spots. Close won't cut it. The bigger the tire, the more precise the tech has to be.I'm getting vibrations between 20-40mph in 2-3 gear dash shakes some then smooth's out till I go into 5th gear then there is more vibrations just not as bad if I down to shift to 4th it goes away. Please help. It's not in the steering.
Hell, I say grease it up and run itFound the cause of my vibrations......
So what part is that?Found the cause of my vibrations......
It’s whats left of the U-Joint from the rear drive shaft.So what part is that?
