Vintage Jeep boom box
Drizit
1,244
Canada
Looks way nicer than mine, turned out to be water damaged and I need to rebuild some of the boards.
There must have been a time
when we could have said no.
Shawn’s TJ
Shawn’s TJ
117
Wisconsin
Yeah looks are deceiving! It works but i get hardly any sound. Its very low and comes out of one speaker only. But if you use head phones it sound nice and loud no issues. The tape and CD player still works.
Drizit
1,244
Canada
These days a CD player IS vintage. It doesn't have line in, usb, or Bluetooth... Its old school ;)
I'd pop the lid off and check the speaker wires, I bet you have some broken solder joints or a bad amp chip in there.
Oh and as a side note, most of the chips on the amp board are Sony ;)
Reactions: MaloStapalo
Kiwi TJ
I don't suffer from insanity I enjoy every minute
4,326
Auckland New Zealand
Come to think of it, it does resemble the old water/shock proof Walkman
Drizit
1,244
Canada
Man I remember those, with the big plastic latch on the side to keep it closed.
Reactions: Kiwi TJ
Jeep9748
511
Ohio
Mine looks exactly like that, except the volume pentameter doesn't work so it is super quiet. But hey it is cool.
Shawn’s TJ
Shawn’s TJ
117
Wisconsin
I just get such a kick when someone calls a boom box with a CD player "vintage". :risas3:
well you should really get a kick if you read teh thread heading were i called it a "Relic"
This radio does the same thing, and the worst parts is i don't JACK about electronics. It's sad because the radio is really neat and seems to be built pretty good on the outside at least.
Jeep9748
511
Ohio
I didn't really know anything about the radio. I did some research, since then I have discovered someone has one and used a Bluetooth type setup (far beyond my level) to run the speakers and listen through it. I am just putting it with the Jeep collection.
Drizit
1,244
Canada
That seems to be a common issue, (looking at the broken ones on ebay) on mine I found what looks like water damage on one of the amplifiers. Im starting to wonder if it just blows out for other reasons. The chip can be had off eBay for a couple bucks. If you can solder I'll dig up the part number. Don't know for sure that's the same chip for yours but it's possible.
Jeep9748
511
Ohio
UPDATE! This radio has been on my shelf just collecting dust so i decided to do something about it. Here's the results...
WOW that's EPIC!!!! I think I will borrow this idea for my Jeep Boom Box. Only question is how did you wire the radio for power supply? 12V or 120V ?
Reactions: VallenMaes
Shawn’s TJ
Shawn’s TJ
117
Wisconsin
That was easy. The systems was original a 12 volt system ( see the back of your Jeep boom box) and my jeep Boom box came with the original power pack which plugs into the wall and reads... 120v in /12 volts out. so i wired that to the original power bank from on the jeep radio so that solved that problem. Also, i kept the batter compartment intact so it also works on 8 D size batters which is expensive so i won't use that option. Moreover, I found another power jack that's the same as the original jack on the power pack and weird tat plug to a 12 volt plug so it now it can plug it into a 12volt /cigarette plug in the car.
The trick is to use a newer car radio that is bluetooth and has no CD, because those units are very small and use very little power.
Reactions: Kiwi TJ
Shawn’s TJ
Shawn’s TJ
117
Wisconsin
A guy can do a lot with those CD-less Car radios because of there size. In my Humvee I was able to install a Pioneer radio and cobra CB all inside an Ammo can. Moreover, i also was able to get a mini glove compartment too. See Pictures.
The decals on the Ammo can are not accurate, the can is a 50 Cal
Drizit
1,244
Canada
That's a cool build. Can't wait to get the amp boards fixed in mine.
