Windshield frame bolted it....loking great...next week engine and tranny cooling and e-brake cables.
Fascinating build you’ve got going.
Thanks....we're on track to finish this build by June...cant wait for the shake-down trials!
the shake down runs are great. I thought I had everything tip top after the (diesel install. 2” lift. Dana 44 swap)
forgot to add gear oil to the rear axle. So I’m all that work I had basically throw $1200 in the trash. One heck of an expensive lesson.
What kind of diesel did you swap in? How do you like it? How does it handle compared to stock?? Fuel consumption?the shake down runs are great. I thought I had everything tip top after the (diesel install. 2” lift. Dana 44 swap)
Hate hearing stories like that... I have a few of my own I could tell. I will be sure to to put that on the final to-do list as both front and rear pots are empty.
Went out for a test drive and was about 2 miles away from the dealership when the rear axle LOCKED UP...…..
In 2000 I bought a 2000 Impala wrecked...car had under 2000 miles on it....it was an insurance write-off....put a complete front end on it....had to change the intake manifold (the 3800 has a composite intake, not aluminum) because it was cracked in the accident. Instead of putting a new intake on it I got one from the wreckers to save money. Bolted on the new intake and started the car....everything was great until I started to fill the cooling system with coolant.....started hearing some gurgling sounds and then a big bang and the engine died! Looked under the car and saw pieces of the block and lots of dripping oil and anti=freeze!! That wasn't a good day.I worked in a dealership and was a heavy line mechanic and was regearing a truck for the phone company. I was so excited because I was done early and was going to make bank on the job. Went out for a test drive and was about 2 miles away from the dealership when the rear axle LOCKED UP...…..
Talk about a walk of shame... The housing was toast and they had to order a new complete rear axle. I've made my mistakes over the years but hope I have learned from each of them also.
I got 30-40 miles on the dry axle. I think I had that many because I was running front wheel drive while I waited my Tom woods driveshaft to arrive.
Looking back all the signs were there. But being interior Alaska I thought I was having traction problems on the ice. Not that my rear axle was seizing up
This is so sickSince the start of the semester we have been working on mostly wiring and getting the tail gate assembled, lined up and installed. Have a bunch of girls in the class and am glad for that because they have lots of patience, will do exactly what you tell them and will ask questions if they don't undetstand...they are doing the wiring...which on this project is a formidable job...the Liberty has tons of wiring we don't need...so they are identifying the circuits we're not using (like power windows and locks etc.) and eliminating them....they are also identifying wiring that we are using and either lengthening or shortening it to accommodate the TJ and wiring in connectors from the old TJ harness....so far we have the wiper motor working, the horns, windshield washer system, front headlights, still working on tail lights....all is going great!
