Thanks Grant....the students are all watching this build thread and are keenly interested in all the comments....thanks for looking.....and all of your input/suggestions are appreciated!
Honestly and I know it's kinda petty and realize I'm joking, but I kinda hate how the modern diesels are so quiet and not as cranky as their ancestors. If I hear a turbo on a Jeep, I'm like a dog that senses something, I'm heading that way to check it out especially a diesel and no one seems to notice that there's anything different at all. It only kind of sounds like a diesel from about 1k to 1,500 rpms and just barely and then to me the turbo is obviously a turbo, but quiet.
I'm loving these builds on the TJ forum. I have to admit the VM 2.8 seemed like a great build to me, but I was too scared to tackle the electrical part. The TDI build I looked at doing the electrical and that kept me from just diving into that build when I first got the Jeep. My preference is as much displacement for a diesel as possible, as long as the weight is considered. 3L and just below seem to be where it's at for general purpose on and off-road sub half ton vehicles. I'm sure 1.9 is plenty as well, but there's times where your turbo isn't spooled that more displacement is probably better. I guess gearing can compensate, but gearing can be unforgiving. Also about 300 ft lbs of output from the engine of a TJ is something every TJ owner should feel.
To be honest with you, the amount of wires and the size of the harness that we pulled out of the Liberty is unreal and quite intimidating. We are not just using the engine harness but the entire wire harness (engine, transmission, body control, ABS, SRS etc...). At the same time I'm confident that we'll get it installed and everything will function as it should....what I'm going to do is take the harness home for the summer break and prune it down to the essentials.....for example, the 4 door wire harnesses that make up a sizeable amount of wires can be removed, also the rear gate, sun roof, etc....so much of the harness can be pruned down....I all of the wiring diagrams and so it will just be a little time consuming identifying and pruning the wiring. Also to help us along, I had my students label with masking tape and marker, every connector that we know we will need for the swap....so yes....I'm also scared about the wiring....but at the same time I'm confident that we'll get it done....
Thanks for your comments...keep them coming as the build progresses!
Going to try to install cluster into dash before school lets out for summer...I'm pretty anxious to get that done..was even thinking that I might get another 2005 liberty cluster from the salvage yard to use as a test mule..... especially if we have to start carving up the cluster case or transplanting all the innards of the cluster into the tj cluster casing.Wow. I just love the prep and detail of this build. There's always been a part of me that wished I'd completely torn mine down and fixed everything, but honestly I was just trying to get mine back together before something broke on my truck, which happened a few weeks after starting to drive my Jeep again.
I know it's going to be awhile until you get to it, but I can't wait to see your dash when you're through.
I'm not sure...I've read online somewhere that the gasser cluster will work in the crd but tach rpm is not accurate...size and shape of the two clusters is the same...Are the CRD clusters specific to that engine or are all similar year Liberty's the same?
Tach always seems to be the issue for diesels. Where does the VM get the tach signal?I'm not sure...I've read online somewhere that the gasser cluster will work in the crd but tach rpm is not accurate...size and shape of the two clusters is the same...
I'm not sure but I would guess the crankshaft position sensor..Tach always seems to be the issue for diesels. Where does the VM get the tach signal?
Makes sense. I just remember there was something weird when I was looking at keeping my stock cluster, but I ended up using a converter or something with the tach signal generator from the Cummins ECU.I'm not sure but I would guess the crankshaft position sensor..
That is our saving grace having the complete doner vehicle...if you have wiring diagrams and enough patience..you can make everything function correctly.Makes sense. I just remember there was something weird when I was looking at keeping my stock cluster, but I ended up using a converter or something with the tach signal generator from the Cummins ECU.
If your diagrams are correct that is...But again I didn't spend the money and do it right either, just used some free stuff.That is our saving grace having the complete doner vehicle...if you have wiring diagrams and enough patience..you can make everything function correctly.
That is a beautiful color...Mine is getting a respray and that is on the short list. Did you need to do a silver base coat, like a candy apply color?Hydro blue (Dodge/Jeep colour) in satin finish...body goes on Monday...then we can take measurements and install motor mounts and plant the powertrain
No silver base coat..just regular hydro blue base coat with dulling agent in clear coat...That is a beautiful color...Mine is getting a respray and that is on the short list. Did you need to do a silver base coat, like a candy apply color?
