Alright, I’m lost on this one. I’ve talked to warn twice and they are lost.
Xd9000i- I’ve replaced all of the wiring up at the solenoids and switched to 5pin adding in the ground to motor lug. All solenoids replaced very recently. Controller is new. Motor is 2 days old. Leads are in good shape and 1 gauge.
Symptoms- when I hook up the leads to the battery there are large sparks and the motor will do nothing. The power lug got so hot the other day testing it that the boot melted partially. Today with the new motor installed I tested with jumper cable and the terminal connected to the neg on the jumpers starts smoking.
I also have a 9.5ti I hooked up using 6 gauge jumper cables to test tonight and same problem, nothing happens.
Alternator is 6 months old, battery is fresh and 12.8 volts. I’m losing my mind trying to figure out what’s going on with this one.
Thoughts ? How do I troubleshoot this at this point ?
