Warn XD Restoration
Irun
What I want isn't as important as what I need!
Virginia
I picked up a Warn XD and would like to do a light refresh. Although it's a little weathered, it appears like the steel cable hadn't been unwound and the winch looks like it wasn't really used. After doing a quick visual inspection, all I see that's needed is:
- 2 Gauge Power Cables (To the battery)
- Tie Rods (Warn 98279 Service Kit)
- Winch Mounting Bolts
- Contactor Pack Mounting Bracket
- Replacement Warn Stickers
That said, are there any tricks I should know about when taking this apart to do an inspection?
Second question, does anyone know the part number for a mounting bracket for this version?
Irun
Irun
Virginia
I looked up a couple of videos and taking it apart seems relatively simple. After a partial disassembly, it doesn't look bad at all inside.
Blackjack
Evil Winch Doctor
Kenai
That thing looks basically unused. Solenoid bracket is PN 26368 and I have some I will be putting up for sale if you want one. If you get new tie bars you will want to make sure and actually tap them and not try to cut threads with the self tapping screws they come with.
You will want to pull the motor cap and put a couple drops of oil on the bushing and let it soak for a few minutes since it was used so little.
Irun
Irun
Virginia
I didn't realize the Tie Rods were aluminum, so I cleaned those up and should be able to reuse what I have. I'll definitely pull the motor cap and oil the bushing. PM sent on the bracket. Thanks!
Reactions: Blackjack
JMT
Definitely a Snowflake ❄️
Looking forward to this! Love to see these come back to life!
Reactions: Irun and Blackjack
Irun
Irun
Virginia
I was under the assumption Warn was Made in USA. What's up with this?
JMT
I believe that means the winch was made on the “Darkest Day of America” which was evidently July 11.
I believe that day had the highest gas prices ever and yes it is Biden’s fault.
Let’s Go Brandon!
Hope that’s not a harbinger of how well the winch was made! 😉
Blackjack
Evil Winch Doctor
Kenai
Warn had used Bosch of Brazil for motors since the 90s. They could not get a domestic motor manufacturer to provide what they wanted. After Bosch closed the plant in Brazil in the late 2000s they currently use Saco whos plant is in Asia.
Reactions: Irun
Irun
Irun
Virginia
Power cables came in, but I'm wondering if I went to big?
Irun
Irun
Virginia
Figured it must be something like that. It's a very serious motor! (y)
Irun
Irun
Virginia
Can someone point me to a wiring diagram for this winch? I'm not finding where to connect the negative and positive to the battery.
