Have a question I need some help drove my 97 tj to work last night and stepped out of it for a sec with it still running and noticed a really bad grinding, chattering noise coming from it checked it over this morning and seems to be water pump pulley loose had some play in it (not leaking or anything) do u guys think the water pump itself is the problem never noticed any noise before motor runs slick as a ribbon has never had any signs problems everything I've read says that it will be a gradual problem that will eventually leak but it sounds awful should I go ahead and replace it? Thanks for any advice
