I'm going to make a new Jeep bumper sticker that says, SORRY CAN'T WAVE... TOO BUSY SHIFTING
You know what does suck about a manual? When I'm cruising with my foot out the door, left arm on my leg, steering with my right, relaxed...I'm going to make a new Jeep bumper sticker that says, SORRY CAN'T WAVE... TOO BUSY SHIFTING
Yea,You know what does suck about a manual? When I'm cruising with my foot out the door, left arm on my leg, steering with my right, relaxed...
Then the dude in front of me taps the brakes and I have to adjust everything to downshift. In those moments I yearn for an auto.
I only tell them they are wrong when they are wrong.It doesn't matter, and there's no point in trying to convince anyone else to change, that I agree on. But I do like to hear what people's preference is and why, it's interesting to hear their reasons.
Like Jerry with his autos, he's so damn passionate about them. or the guys who want to teach their kids on a stick, because it's a dying art.
It's cool to read those stories and telling your own without being told you're wrong.
Just my .02 ... resume the bickering.
Up and downshift without using the clutch, yes. Jeep, car, truck or motorcycle.So, I ask again. Can you manual guys shift without using your clutch ?
Not on the Jeep, at least not well enough to want to get good at it.So, I ask again. Can you manual guys shift without using your clutch ?
I don't know enough about transmissions too understand why, but some are easier to float than others. At work, we had an old Freightliner FL60 with a 6 speed that was very easy to float. Very fun to drive in the mountains. My mother's '03 Mini Cooper S also floated easily. Her '05 with a different tranny is not. I've tried most manuals been able to spend time with and some work more smoothly than others. Some just won't let you float.
When I had my old YJ I drove it from the Bay area to Chico. When I was up there going to school my clutch went out so for the next month or 2 I was forced to drive without a clutch until I brought it back down to the bay where all my tools were. I could put it in first and engage the transmission but after that the clutch no longer did anything so I had to up shift and downshift without it. If I couldn't get all the way back down to first before a stop sign or signal light then I would need to turn off the engine, put it in first, then drive away.So, I ask again. Can you manual guys shift without using your clutch ?
Yes, up and down all gears except for first. I always use the clutch going in and out of first.So, I ask again. Can you manual guys shift without using your clutch ?
So the answer is yes I have drove without the clutch and on occasion will still do it for a shift or two on the TJ but by no means would I say I do it often.
I suspect that wider ratios (longer gears) also help. The NV3550 used in the TJ is a close ratio, according to Grimmjeeper.com.Yea. It’s all rpm’s. I had a Mazda Protege that would float real easy. The big trucks I only use my clutch in 1st or if I need to dump it quick
I see the disdain for using your wheel brakes offroad. Why is that a problem? That's what they are for. You use them on the street, what's the difference except when in low and locked, they work even better since the combined braking force is used on all four tires, exactly what you want it to be.
Autos must be driven, it takes skill and practice to ease up with smooth throttle input, gently use the brake down the other side so you don't look like a big basketball someone kicked down the canyon. Even harder for folks to master is the ability on a hard climb to give it just enough throttle input to keep the tires right at the limit of adhesion.
Years ago in that old Freightliner, the clutch started to slip somewhere north of Amarillo, TX. I floated it nearly 400 miles all the way past Colorado Springs, CO before the clutch completely failed just after the weight station in Monument during rush hour traffic.That awesome! Lol. Floating by necessity
