What all should I do before adding a supercharger or turbo?
Torqythewrangler
Va beach
I eventually want to put either a supercharger or a turbocharger on my 2005 4.0I6. I wanted to know if there is anything that I should focus on before doing this upgrade. Also what would be better supercha or turbocharger or both? Any help would be greatly appreciated.
Reactions: RobertJ
Hooooooo boy. This could get messy.
Lets start with some basic questions:
  • How much power do you want to make?
  • What is your budget?
  • What does your jeep have for axels?
  • What transmission do you have?
  • What experience do you have with tuning / mechanical wrenching? (Just asking, not shaming)
  • What is your end goal? (daily driver, trail rig, bit of both)
I can also tell you right away that you do not want to do both. It's not practical.
Also. please fill in your profile as much as you can. It helps us all.
Always both. ;)
Reactions: Mikee024
Exactly why do you believe you need a supercharger or turbo charger? Is it simply from a lack of power that keeps you downshifting or unable to keep up with traffic? If so your axles may simply not have the right ratio gears installed for your tire size, transmission type, and engine size. Your Profile has no information in it about your Jeep so 1) what model year TJ do you have, 2) What size tires are you running? 3) What transmission do you have, automatic or manual transmission? And 4) do you have the four or six cylinder engine?
Then tell us what your axle gear ratio tag says, it is bolted onto the differential cover at its 9 o'clock position like this one indicating the ratio is 3.73. What does yours say in addition to the four questions above? And if you leave any of the four answers we won't be able to make a ratio recommendation to regear your axles to. If the ratio proves to be the cause of your lack of ratio it'll be an easy thing to take care of and a lot less $$$ than installing a turbocharger or supercharger.
I’m a fan of the turbo.
Some items to confirm before installation:
- engine cooling system works properly
- no vacuum leaks
- no exhaust leaks
- transmission shifts well and doesn't overheat
- gearing for your tire size is correct
- engine compression numbers look good
- steering and suspension are in good shape
- motor and trans mounts are good
- switch to a 2.5” post-cat exhaust (mine is 3” but that’s not necessary).
I've got a roots blower on my TJ. If you're just looking for performance, my ranking of suggestions would be as follows:
Proper gearing.
Stroker.
Stick with NA and learn to appreciate the simplicity.
Centrifugal SC like a ProCharger, with an intercooler.
Turbo with intercooler.
Roots/screw/etc supercharger with an aftercooler.
Roots/screw/etc supercharger with meth injection. (where I am)
In other words, if you're forcing air in, do it in a way that allows you to run a good intercooler.
I would also recommend tuning the PCM directly with the proper injectors and map sensor, vs dicking around with a piggyback. HPTuners work well with your factory PCM. Of course you ask what to do before boosting... well don't forget all the supporting parts. The tuner, wide band o2 and guage, boost gauge, 2bar map sensor or better, bigger injectors, colder plugs, etc. If you're going more than 7psi or so you've got a whole additional set of concerns, like head gasket and studs, etc.
Engine swaps are done a lot, I haven't done one, I don't know what the issues you run into along the way are. Adapters are available. My guess would be getting the gauges to all work nicely might be difficult depending on the motor.
I have an SRT10 Ram that I'm currently fighting over the title with the state of MN, so it's just parked behind my garage collecting dust. I have eyeballed the size of that 8.3 v10 many times... :LOL:
They actually fit in there pretty nice
I traced the CEL in the Jeep ECM and connected it to the CEL wire on the LS ECM. That way I technically have a functional light for my engine.
What year is your jeep? I have an 04 and I thought the CEL was integrated into the dash electronics vs having a dedicated wire and light, did you have an earlier model?
