Got the trans pan off and found a bunch of chit had clogged the filter to the point it had started to collapse, starving the trans of oil and stopped the Jeep from moving. Not exactly sure what the crap was. There were no metal flakes in the fluid or filter, just what appeared to be rubber or friction material, the fluid was clean and still nice and red.
I had a hell of a time finding a torque converer for my 97 32RH. The first one I got from O'Reilly's was incorrect ( Pro-King CR63 ) because it had the ring gear intergraded into it and mine has the ring gear on the flexplate. After a lot of research I ended up with one that is listed for a 42RH with a high stall ( Pro-King CR69 ). The CR69 has a 2400-2600 stall and an Offset bolt pattern. The offset bolt pattern wasn't that big of a deal, it just offsets one flexplate bolt and the original hole is easily elongated to accommodate. I did find one torque converter that would have worked without the modification to the flexplate (Pro-King CR90) but it had a lower stall rating of 2000-2200. I just figured I might as well upgrade if I am in there.
And I found the source to my bottom end noise and what my flexplate bolts were hitting. It was the upper dust cover. It was badly bent and had a huge gouge in it. Not sure how this happened, but at least it's fixed now.
I will have the transmission back in tomorrow and update on how things are going.
Here are some pics.
(Too deep!!)
(Gouged dust cover)
(Fixed dust cover)
(Pro-King Torque Converter catalog listing)
