That is my favorite company motto- We suck less
I like my vacuums to suck more.
That's a good trick since none of them suck anyway. All they do is create low pressure zones that air moves into.I like my vacuums to suck more.
That is my favorite company motto- 'We suck less'
Yes, they don't.I’m looking at getting the Yukon locking hubs for my TJ, my primary reason would be for the ‘fuse’ component…would love to have that as the most likely (no guarantees) failure point in the event of a high stress load. Read this thread, but hoping more people might chime in and comment if the Yukon locking hubs behave that way.
Thanks
Doesn't work that way on the mechanical side and you don't want it to. The reason I said Yes they don't is because sometimes the hub breaks, sometimes the inner 27 spline breaks, sometimes the u-joint breaks and sometimes you break a u-joint on one side and a locking hub on the other at the same time.Then not sure they are really worth it to me…love the idea of a weak point in a system (electrical engineer in me) to protect the more delicate and costly/complex components to replace.
Plus, I’m not a hard driver, but every now and then I might be prone to doing something stupid….Yep, sounds like not worth it especially for the cost! Think I’ll just find a bit more room to carry a spare unit bearing and outer shaft…if anything breaks upstream of those, just disconnect/remove problem and live with 2wd…
Thanks!
You're more apt to damage an inner than the outer stub. I would suggest if you're going to carry spares it should be the inners and at least 1 outer and and extra ujoints.Yep, sounds like not worth it especially for the cost! Think I’ll just find a bit more room to carry a spare unit bearing and outer shaft…if anything breaks upstream of those, just disconnect/remove problem and live with 2wd…
Thanks!
In the last two weeks I have replaced a broken hub, a broken u-joint that took out the stub shaft yoke and a broken stub that twisted off at the back face of the unit bearing.You're more apt to damage an inner than the outer stub. I would suggest if you're going to carry spares it should be the inners and at least 1 outer and and extra ujoints.
And that's the "Norm"?In the last two weeks I have replaced a broken hub, a broken u-joint that took out the stub shaft yoke and a broken stub that twisted off at the back face of the unit bearing.
We reused the undamaged inners in all 3 instances.
Norm is hub, u-joint, yokes. If 27 spline inner then those will break depending on a few things but about 50/50. If 30 spline which Brian's are, then almost never but the yokes and joints in stockers, joints which damage yokes. In this case, with 30 spline inners and 27 spline outers, at almost no point will the yokes survive a joint failure in either stockers or aftermarket high strength alloy.And that's the "Norm"?
If only it could be done for $850 today.Yup. Most install them to improve caster/handling and vibration issues. Love mine, best $850 I have spent improving those issues.
You just got done telling him (in a round about way) that the hubs wouldn't be the first to brake, yet here you're saying that is the progression for someone with 30 spline axels?Norm is hub, u-joint, yokes. If 27 spline inner then those will break depending on a few things but about 50/50. If 30 spline which Brian's are, then almost never but the yokes and joints in stockers, joints which damage yokes. In this case, with 30 spline inners and 27 spline outers, at almost no point will the yokes survive a joint failure in either stockers or aftermarket high strength alloy.
If anybody knows, does this mean the locking hub or a normal hub? Are normal hubs a weak point or is he just talking about replacing the Warn/Yukon hub here? The locking hub makes sense but I don't know shit about this stuff.Norm is hub, u-joint, yokes
You do understand I'm referring to a product that Warn made that no longer exists, right?You just got done telling him (in a round about way) that the hubs wouldn't be the first to brake, yet here you're saying that is the progression for someone with 30 spline axels?
View attachment 317622View attachment 317623View attachment 317626
