Hi Jeepers
I am struggling with a problem on my TJ Rubicon 2003.
I wanted to replace the bushings on the axle for the upper control arms. It's a 10 mm bolt that goes through right now.
I ordered Acdelco 45G8088 but the sleeve is like 1/2 inch wide with 3 bumps in the inside to accomodate the 10mm bolt. I really don't like the fit. There is plenty of play which I don't think is good on a control arm.
Do you guys know what bushings I could order with a sleeve with an exact 10mm diameter ?
I was also thinking of upgrading the bolt size to 1/2 inch. Anybody did this already and if so, what would be the bushings I'd need ?
I wish you all a good day !
