Whats up guys, had a question about the motor and body grounds, and the connector/lugs you should use. I was planning on using a 3/8 lug. I want to make sure i'll get a good connection. I don't wanna fry my amp I just installed.
The rear motor ground seems like its tapered. I drilled out the 3/8 to fit around the bolt, is that gonna be ok?
The body ground also had a lug with some kind of teeth on it. Will I be ok using a standard 3/8 aluminum coated copper lug?
Thanks in advance for any help.
