05 TJR
Yesterday I dropped the fuel tank to fix the filler valve inside the tank. I was having the well documented problem of fuel splashing out when filling up for a while, then the valve got stuck in the closed position and would keep shutting the pump after only 1/10 of a gallon was pumped, so it would take 30 to 45 seconds to pump one gallon!
Yesterday I pulled the tank and removed the fuel pump to access the valve inside. I pulled the valve and filed down the 3 little tabs just like in the youtube video posted around here a few times and... success! Well, sort of. I filled up the tank and the valve worked perfectly, stopping the pump when full without spitting fuel everywhere, but now it seems to be losing prime when it sits for an hour or so and takes a couple of attempts to start. After it's started, it runs perfectly. I never had this problem before and it always cranked right up in under a second from a cold start. I first assumed it may be some air trapped in the line as I only made one trip of less than a mile yesterday after the fix, but it just did it to me again after a 25 mile drive to work this morning (but it had been sitting for 3 hours before I tried to start it again.
So what did I screw up? I'm assuming from the symptoms that it is losing prime to the fuel rail, and never having even a hint of this symptom until yesterday, I know it is something I did. I was careful as I lowered the tank and didn't really have any problems with getting the fuel hard line connectors loose or with putting them back together again.
