What did you do to your other vehicle today?
That's a little more in-depth than this old backyard mechanic would ever realize. You could very well be right, but like I said, I'm not familiar with such things. I did find it odd that so many others had used the same brand and model of plugs, apparently without incident. 🤷‍♂️
Saab was definitely a vehicle known for quirky engineering like that but you never know haha. But sounds like you might be in a different case
Reactions: Squatch
I had a similar issue with the Ural when I first bought it, Squatch. NGK BPR7HS plugs are spec'd. My first thought, being a cheap bastard, was I ain't paying for NGK plugs. I bought the Champion equivalent. That Russian Piece Of Crap just would not run right. I bit the bullet and put in the NGK plugs. Problem solved. I run NGK plugs in just about everything now, even the DeSoto.
As far as cost of the NGK plugs for the Ural, I usually buy four at a time. That's usually around twelve to fifteen bucks and equals two years of riding. This past Wednesday, Mrs.Cheesy and I drove up to Woodstock, IL to check out the Habitat For Humanity ReStore* there. I found ten individually carded NGK BPR7HS plugs for a buck each. Set for the next 5 years.
*The local ReStore closed when the building was sold and has yet to be relocated. I've outfitted my woodshop with power tools from ReStore.
  • Love
Reactions: Squatch
I did an antifreeze change the other day, and today I changed the spark plugs on my Crosstrek. For a boxer design, the front two spark plugs were easy. But, those rear two spark plugs were a battle of persistence.
Not today, but yesterday. My 1998 Subaru Impreza daily driver started having "hard spots" in the steering wheel rotation early in the week. My LJ has been up on my lift for weeks for the rear frame raise portion of my build, and I completed everything but paint last weekend (see my build thread, if that interests you). I got home early enough a few times this week to get it painted, lower the body back onto the rear of the frame, and put the wheels back on over the course of a few evenings.
Yesterday morning, I put the Impreza up on the lift to diagnose the steering hard spots. The hard spots corresponded to even rotations of the steering column, indicating to me that it was either a stiff column u-joint or a something worn in the area of the pinion gear inside the rack-and-pinion assembly. To determine the culprit, I removed the four rack mounting bolts and dropped the rack about an inch, which allowed me to remove the steering shaft (really just a very short shaft with a u-joint on each end):
Once I got the shaft off, the problem became obvious. One of the four joints was extremely tight. Here's where it got interesting. Driving a 26-year-old vehicle for a daily driver can be a challenge because when you get a few hundred miles short of 400,000 miles, parts start wearing out that were never expected to wear out - like a steering u-joint. There are no new steering shafts to be found anywhere! [Side Note: I had a similar problem a couple years back when I rebuilt the engine, but that one didn't make sense - no new pistons available from any source. Really? Pistons wear out.] But, I digress. Back to this story...
I found exactly one used shaft on eBay, supposedly from a 103,000 mile vehicle. It's now on the way. However, I didn't want to leave the Impreza on the lift while waiting for this to arrive (and I also prefer driving it to the office every day over my Expedition), so I decided to put it back together with the old shaft for now.
Before doing so, I decided to see if I could encourage some range-of-motion back from the old shaft. I have used Tri-flow Spray Lube for decades. It's very light viscosity, so it flows through capillary action into tight spaces well, and it has Teflon in it. I grabbed that can and sprayed into the gap below the rubber seals and worked the joint. After a few tries, it freed right up - almost as good as new! So back in it went.
Of course, without being able to get proper grease in there, it's eventually going to tighten up again, but it's a steering column, not a driveshaft, thank goodness. I'll likely shoot some Tri-flow Lube in with every oil change. I'm going to just drive it until it tightens up again. I'll then just try re-lubing it, and if that doesn't work, I'll put the eBay shaft in.
Sold it. Or one of them, anyway.
We bought this Accord for my wife to commute to school with it, and saved 35,000 miles that would otherwise have gone on our family hauler 4runner. She's out of school and got a job close by so we don't need it anymore. We're the 2nd owner and it's a 4 cylinder auto base model with 162k miles.
Listed it at the top end of kbb private party and had 26 messages, ended up selling to the 2nd looker who drove 50 miles to see it. Came down $400 on the price because it's due for new transmission fluid and will need tires within the year, but it was gone in less than 18 hours from being listed.
Upgraded the front speakers in my DD (Ram 1500) to Focal ICU 690. Having a little fun being a youtube speaker installer. I changed out the front and rear 6X9 and dash 3.5" speakers. Then had a shop install an Infinity 5 channel amp and JL sub.
I started with Infinity Reference speakers to replace all the OEM which will work without an amp. After getting an amp, decided I want something better up front. The 6X9 were from Crutchfield, so they were right at the end of the 60 return policy.
One of the remaining vehicles got a wash and wax. I bought this truck in 2019 and the paint is pretty rough so I end up thinking of it as a beater and it gets neglected. I think I washed it once in 2020.
I didn't even bother with the roof but I suspect it looks similar to the hood, which was pretty rough. Next time its dirty I'll wash it and actually get up in the bed and really clean the roof and wax it, too.
The hood still doesn't look awesome from a gloss standpoint but it darkened up pretty well. This shot was when I'd done the driver side but not the passenger.
With the Honda gone I have an open bay in the garage but this thing is so dang long I'm not really that enthusiastic about parking it in there and making it harder to get around.
I just love old trucks like that. It doesn’t take much to keep them on fairly dependable stand by, you don’t need them to be pretty and they are so useful. I have an old flatbed I don’t think I’ve ever washed (except the windshield).
Plus there’s something about driving around town in a grungy old truck that makes me smile.
Toughest job of all: Replaced a running lite bulb in the right tail lite of the old MBZ! ;)
The bulbs in that thing seem to last for 1.2 forevers, I don't recall changing that one before but maybe I did. The rear right side lite bulb was burned out when I bought the car in Y2K. I replaced it with a bulb that I had gotten out of a 1967 220S finback several years before. 24 years later, that bulb is still working!
I just love old trucks like that. It doesn’t take much to keep them on fairly dependable stand by, you don’t need them to be pretty and they are so useful. I have an old flatbed I don’t think I’ve ever washed (except the windshield). View attachment 556680
Detroit or gas?
What year is it? I have a ‘99 that I got in January 2000. It was the last ‘99 they had on the lot. It has more years on than milage at 186,000. Headed out to WV in it tomorrow to visit family.
A drunk driver totaled the ‘91 short bed 2WD I had before it. I loved that fuel injected 350 in that truck.
mine is a 2000. Similarly, about 160k miles so it's technically "low mileage" for it's age. The interior is really clean, but it was clearly not garaged. My intent for it was as a work truck and to sell it when I was done, and I found it with some electrical gremlins that I knew I could fix inexpensively so it was a pretty good deal and I wasn't concerned about the condition at the time. It's been such a useful truck that I've kept it years longer than I planned, the exterior condition has bothered me more. The paint has a lot of sun damage on the horizontal surfaces like discoloration, crows feet, etc, some scratches that were neglected by PO and allowed to rust, and for whatever reason the driver side in particular has 3 different large but shallow dents that I'd like to straighten out. The bedside fender arches were completely rusted through but covered up with body putty and paint, so I ground all that out and POR-15'd the crap out of them, then covered them up with those fender flares.
Yours looks great! One might guess I'm partial to red...
Thanks. Mine has mostly been garaged or under a carport. We just got the topper off Craigslist around 2012. It has some bad sun damage that I somewhat recently noticed, so I may get it repainted sometime. The truck paint itself is in good shape, I just need to do a good polish and wax job on it. (That pic is from a few years ago). I’d like to get some new wheels as the clear coat is shot on them now. She been a good truck.
New front tire on the sidecar rig yesterday. Mounting motorcycle tires sucked fifty years ago...and it still does. But the end results are nice. Also took the time to find out why my front brake was pulsating. I was figuring a warped rotor but the rotor carrier was slightly tweaked. Five minutes with a drift and a BFH changed its attitude.
Note to self:Self, pull the rotor off the wheel before you do anything else in case the wheel falls over and lands jelly(rotor)side down.
I literally just dropped off a new rear tire and a loose wheel for the Harley yesterday.
It's ready to pick up this morning.
I'll get the thing put together either today or tomorrow, just in time for a Saturday ride... if these local fires haven't closed all of the freeways and mountain roads by then.
Reactions: Cheesy
Bought some used Harley bags from a police cruiser for $30. Online, these things can go for hundreds of dollars. Plan is to buy the brackets and fab them a little bit to mount to my Honda. Of course they'll need to be repainted to a billet silver
Also, sold the flatbed trailer I bought back in June. The thing weighed 2400 lbs, and was a steel tilt deck that I didn't originally want. Plus I didn't enjoy paying the $115/mon storage fee. Listed on Facebook on a Sunday and within 20 min had 5-6 people interested. The second one came with cash in hand.
