Does this little turd qualify as one of my other vehicles?
1972 Kitty Kat. One year behind the DeSoto in family seniority. My dad bought this in 1979 for my oldest when she was about five minutes old. It's been through both my kids and my brothers' four. It was last at my oldest's place in Maine for her kids. It started having running issues a few years ago, so it was parked in my kids' shed. For a long time.
I had them bring it back to Illannoy last summer so I could get it running for Eli and Owen this winter, then I'd haul it to my brother's place in northern Wisconsin next year. I have four grand kids. I think he has enough to field his own baseball team.
I started to tear into it last August. The fuel system was completely plugged up. While going through the carb, I learned that most fuel and ignition system parts for the nearly 50 year old Kawasaki T5B engine are made of Unobtainium. They can be worked around. To a point.
I got it running, poorly, a day after I started on it. It would run, then just quit. I figured it couldn't hurt to reseal the engine and give it a tune up. Now I'm where I can't get points or a condenser, but I can get an electronic ignition conversion kit. Cool beans. I get new gaskets and seals in the engine this week, along with the conversion kit. Rings and bore look great. Get the engine mounted back in the sled so I can check for spark. Wow! You know the spark is good when you hear, as well as see it. Hooked up fuel, set the choke, pulled the rope. Nothing. Shot some 'Start, Ya Bastard' down the carb and pulled the rope. Ran for a few seconds and quit. Tried the ether again. Nothing. Not good. I already suspect carb problems but I thought I had my sparky issues fixed. Pull the plug and check for spark. Shit.
I end up checking the entire ignition system for bad grounds, broken switches, broken wires. I even checked the coil for resistance. Coil is supposed to be 5100 Ohms, + or - 20%. I got 4200, so it's within spec. Everything else is good, so I have to assume I have a bad ignition module. Double shit. I remember that I had that same module on an old mower, so I pull it and plug it into the Kawa. Great spark. Pull the rope with the carb on choke. Nothing. Try some ether again. Fires up and quits. Try ether again, nothing. Pull the plug. No spark again. Arrrgh! I do a quick check on the on the coil. Way out of spec. And, I can watch the resistance change as the coil cools.
Well, found the cause of all the problems and arrived at that point where I give the engine the last rights and make it a door stop. No coil available and no work around for it. Soooo....this...
...is going to go here.
