You know you'll be scolded if you do!
I am local to some Forum peeps who I may talk into holding my hand while I install mine. I could redirect the blame to them.
Now that's using your brain!I am local to some Forum peeps who I may talk into holding my hand while I install mine. I could redirect the blame to them.
I don't think mine (2006) has anything like that. At least I don't remember seeing it last time I had the cowl off.After pulling off the cowl to help @phraza I had another look at my 'very' rusted bracket for holding the cowl in place.....why any designer would put sponge around a metal part beats me but it did its job at holding water right around the bracket and rusted it....
Its spot welded so I think Im going to have to make my own bracket and drill out the old one (when I say drill I meant just blow on it and it should just crumble haha)
I'm trying to think of a quick fix for now...
View attachment 275572View attachment 275573
Mine is a 1998 maybe they hadn't learnt that water and metal don't mix by then hahaI don't think mine (2006) has anything like that. At least I don't remember seeing it last time I had the cowl off.
That Florida sun!Went from this:
To this:
In just 6 months. So today, I received and installed this:
This one was recommended by Chris in another thread. US made, and actually cheaper than the first one. Yea, it needs a bit more massaging to look its best...
I'd *really* like to get 1 year out of this one...
Last week I suddenly noticed I had lost the 2 lower speeds on the blower fan. So I took the blower motor resistor out and checked it. Sure enough 2 of the pins registered open circuit. So off I go to pick up a new resistor. Checked the wiring and switch connections just to see if there were any signs of overheating. Everything looks good (at this point). If it happens again I may need to look at the motor itself to see if it's drawing excess current. Does anyone know the nominal current draw of the blower motor at high speed on a (good or new) motor?
My 1998 had the same stupid foam in the same place. Luckily, I found it a long time ago and before too much of the steel bracket rusted away. I cleaned it up and primed and painted it. After 10 years, it still looks great. I empathize with you.Mine is a 1998 maybe they hadn't learnt that water and metal don't mix by then haha
Honestly, its pretty difficult to install them with the nutserts allowing the screws to be perfectly centered on the top holes (I mean PERFECT). This is after installing 3 sets (one over again on my TJ because it was installed incorrectly)I am skeerd of not installing them correctly.
Did you rip the sponge /foam out in the end ?...I can see a the point of it being there !!My 1998 had the same stupid foam in the same place. Luckily, I found it a long time ago and before too much of the steel bracket rusted away. I cleaned it up and primed and painted it. After 10 years, it still looks great. I empathize with you.
I can feel the rust crumbs falling into my eyes just looking at that picture. Good on you for gettin' er though!Finally had a chance to make some progress on the lift. 3.5 hours to get almost all of one rear shock out. Now to figure out how to get more rust converter spray. Currently on day 2 of Covid quarantine due to the whole family testing postive on CoVid-19
