I should have started a build thread when I first joined the forum but figured I was already close to the end of the build so I didn’t….. Now I’ve done high lines, installed a trans cooler, done lots of maintenance work, swapped shocks for the 4-5th time, made a DIY front bumper and in the process of making my own sliders, rear bumper plate and rear tire mount. On top of all of that, I’m building a HP30. Hell im even considering building a HP44 out of an old f-150. May end up starting a build thread soon enough.
Anyways, last night I got my blackmax shocks installed. For the rear I didn’t use the “socket mod” but I moved them up to the top of the stock location. Gave me an extra .5” of uptravel. On the front I’m at 4.25” of uptravel and 4” of uptravel in the rear. This is not ideal but my near future plans will fix this.
In the front on the HP30 I’m building I’m going to remove the stock axle mount and weld in one that will lower the mount about 1.5”. With my current suspension setup 5.75” of uptravel is all I can afford before my tire comes in contact with my fender. The rest will be down travel. I may change out my front springs and spacer and use a taller spring with a .5” or .75” spacer to get me the room to have 6” of uptravel in the front. We will see.
In the rear I’m going to be dropping a lot of weight and switching springs. Based on my math that should put me at about 5-5.5” of uptravel. Which will give me a near perfect split on travel. I’ll be waiting on ordering new springs until I drop the weight.
Picture below shows 5.75” of up travel and its limit on my Jeep. Next picture is of the rear shock mount.
