kincaid.0678
Martinsburg, WV
You know, when you get it where you want it eventually, think of how good that will feel. You brought her back to life and that’s something to be proud of.
Awesome that your wife and daughter are on board.
Keep sharing your progress. We’re rooting for you.
I really don’t have too much left to get it there. Passenger side body mounts, JKS 1-1/4” body lift, motor mount lift, rebuild the rear track bar and get the rear axle centered , and I have some new Rancho 5000x shocks to put on it so I can see the light at the end of the tunnel lol I’m sure I’ll do more in the future like lockers and maybe a SYE but one step at a time since I’m not rich lol
AndyG
TJ Guru
Lifetime Supporting Member
Alabama
Channeled my inner @Zorba -
TV ad for a client/friend
I know, I will never live this down.
Mikee024
In a long distance relationship
NYC
Got the pressure and vacuum gauges installed and wired, but not yet connected. They're too brite at nite - especially the pressure gauge. Gonna have to do something about that, either an in-line regulator or a resistor, I'm making a WAG that around 8 volts would be pretty good...
I turned down the brightness of my transmission gauge that was too bright using an inline resistor. Ended up putting a resistor in for my shifter lights as well to match the brightness of my dash.
I used gator clips to test the brightness of different resistors. I then incapsulated mine even though they don’t heat up (just to be safe), and to add rigidity so they don’t break on me.
Mikee024
NYC
Damn dude, you don't sleep anymore then I do.
I might be trippn but it appears you are writing yourself.
Edit: Is that a MXT275VP4? I need to get a setup at some point, but I don't want a big transceiver or big antenna for something I'll use 1% of the time.
Fishtaco
TJ Expert
Perth AU
Passenger window replaced at last this morning! Window fitters have been very busy as there has been a gang going around the last week hitting different suburbs on different nights. window fitter told me to leave my glovebox and centre consul open at night so when they shine the torch in the window they can see its empty and move to the next car.
